Hi there,
When my service goes to output using the update feature process I am constantly seeing a series of errors that come from com.esri.ges.messaging.jms.GeoEventBytesEncoder, the most common are:
- "null java.lang.NullPointerException"
- "An unexpected error occurred while attempting to serialize the GeoEvent to a Byte Array. Error: null."
- "Malformed data. Length is negative: -40 org.apache.avro.AvroRuntimeException: Malformed data. Length is negative: -40 at org.apache.avro.io.BinaryDecoder.doReadBytes(BinaryDecoder.java:336) [18:avro:1.8.2]"
- "An unexpected error occurred while attempting to serialize the GeoEvent to a Byte Array. Error: Malformed data. Length is negative: -40." (this error is coming as an info type in the log when I have it set to debug, full error is in a screen shot below)
I cannot figure out what is causing them at all. During some research, I found that similar errors seem to come from using nesting geoevent definitions, but I am not using nested.
The service outputs into a multipoint and a polygon, both give this error. However, it does not seem to have trouble outputting into a CSV file. Inside the CSV file the data looks perfect and shows no problems. I have tried deleting and manually remaking the definition with did not help. The error is not constantly happening, it seems to come and go.
I was curious if anyone has experienced this before. The one that is really confusing me is the data length -40 because I cannot figure out how that is possible.RJ Sunderman
Thanks!
