I am unable to get ArcGIS Pro 1.3 to use an *.emf file as a Shape Marker for a point layer. When I press the File button under the Shape Marker symbol option It lets me navigate to a directory with *.emf files and pick one, but when the browse window closes the displayed example symbol does not change and the Apply/Cancel buttons do not activate. All of the other options (basic shape, style and font) work.
In ArcGIS Desktop 10.4 I am able to use these *.emf files as point symbols using the Picture Marker Symbol option. If I import an .mxd from ArcGIS Desktop that has a layer containing *.emf point marker symbols into a new ArcGIS Pro project the markers are shown correctly, but I am unable to create that layer within ArcGIS Pro itself even though the ArcGIS Pro help says that *.emf file Shape Markers are supported..
Has anyone been able to set up a layer that uses *.emf marker symbols in ArcGIS Pro? What behavior do you get when you select an *.emf file as a Shape Marker symbol in ArcGIS Pro?
Also it appears that point symbols can only use a fixed Rotation angle for all points in the layer and cannot use a Rotation field to set the rotation of each feature uniquely. Is that correct? Is the only work around to create multiple layers that have a definition query for small angle ranges (say 5 degrees) that together cover a full circle and use the midpoint angle of each range as an average rotation for those layers.
