I've modified the sample for reordering layers found at: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layers_dynamic_reorder.html to include a legend. When the layers are reordered or when the lakes layer is added, the legend does not reflect the change. Here's my code:<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>dynamic layer in legend</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/tundra/tundra.css" />
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/esri/dijit/css/Popup.css" />
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; }
.shadow {
-moz-box-shadow: 0 0 5px #888;
-webkit-box-shadow: 0 0 5px #888;
#map{ margin: 0; padding: 0; }
#feedback {
background: #fff;
color: #444;
position: absolute;
font-family: arial;
left: 30px;
margin: 5px;
padding: 10px;
top: 30px;
width: 300px;
z-index: 40;
#layerList {
width: 200px;
.dojoDndItemOver {
background: #ccc;
</style>
<script> var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script>
<script>
dojo.require("dojo.dnd.Source");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.form.Button");
dojo.require("esri.map");
dojo.require("esri.dijit.Popup");
dojo.require("esri.dijit.Legend");
// one global for persistent app variables
var app = {};
function init() {
var ext = new esri.geometry.Extent({ "xmin": -11080843, "ymin": 5585370, "xmax": -9766126, "ymax": 6260462, "spatialReference": { "wkid": 102100} });
var popup = new esri.dijit.Popup(null, dojo.create("div"));
var legend;
app.map = new esri.Map("map", {
"extent": ext,
"infoWindow": popup,
"slider": false
urlDyn = "http://servicesbeta2.esri.com/arcgis/rest/services/USA/MapServer";
usaLayer = new esri.layers.ArcGISDynamicMapServiceLayer(urlDyn, { "id": "usa" });
app.map.addLayers([usaLayer]);
// build the layer list
if (usaLayer.loaded) {
buildList(usaLayer);
} else {
dojo.connect(usaLayer, "onLoad", buildList);
// hide the loading icon when the counties layer finishes updating
dojo.connect(usaLayer, "onUpdateEnd", function () {
dojo.style(dojo.byId("loading"), "display", "none");
// rebuild the layer list
buildList(app.map.getLayer("usa"));
// add the lakes layer to the existing map service
dojo.connect(dijit.byId("lakes"), "onClick", addLakes);
dojo.connect(app.map, 'onLayersAddResult', function (results) {
//esri.show(dojo.byId('legendDiv'));
if (!app.legend) {
//add the legend to show the resulting layer.
var layerInfo = dojo.map(results, function (layer, index) {
return { layer: layer.layer, title: layer.layer.name };
app.legend = new esri.dijit.Legend({
map: app.map,
layerInfos: layerInfo
}, "legendDiv");
app.legend.startup();
function buildList(lyr) {
var lyrInfos, lyrs;
// remove the existing layer list
if (app.hasOwnProperty("dndSource")) {
app.dndSource.destroy();
dojo.empty(dojo.byId("layerList"));
app.layerLookup = {};
// use dynamicLayerInfos if present
// fallback to layerInfos to build the layer list
lyrInfos = lyr.hasOwnProperty("dynamicLayerInfos") ?
lyr.dynamicLayerInfos : lyr.layerInfos;
lyrs = dojo.map(lyrInfos, function (li, idx) {
var lyrName = li.name.split(".")[li.name.split(".").length - 1];
app.layerLookup[lyrName] = idx;
return lyrName;
app.dndSource = new dojo.dnd.Source("layerList");
app.dndSource.insertNodes(false, lyrs);
dojo.connect(app.dndSource, "onDndDrop", reorderLayers);
function reorderLayers(source, nodes, copy, target) {
// show loading icon
dojo.style(dojo.byId("loading"), "display", "inline-block");
// get layer name nodes
var lyrs = dojo.query("#layerList .dojoDndItem");
var layerOrder = dojo.map(lyrs, function (l) {
return app.layerLookup[l.innerHTML];
if (!app.hasOwnProperty("dynLyrInfos")) {
app.dynLyrInfos = app.map.getLayer("usa").createDynamicLayerInfosFromLayerInfos();
var newOrder = dojo.map(layerOrder, function (idx) {
return app.dynLyrInfos[idx];
app.dynLyrInfos = newOrder;
app.map.getLayer("usa").setDynamicLayerInfos(app.dynLyrInfos);
app.legend.refresh();
function addLakes() {
var layerName, dataSource, layerSource, options, drawingOptions;
// disable the "Add Lakes" button
dijit.byId("lakes").set("disabled", true);
// show a loading icon
dojo.style(dojo.byId("loading"), "visibility", "visible");
// layer name in the workspace
layerName = "egdb.SDE.USLakes";
// get existing layer info
// lakes info will be appeneded to this object so it shows up in the map service image
// only use createDynamicLayerInfosFromLayerInfos
// if layers haven't been re-ordered yet
// create a new dynamic layer info object for the lakes layer
dynamicLayerInfo = new esri.layers.DynamicLayerInfo();
dynamicLayerInfo.id = app.dynLyrInfos.length;
dynamicLayerInfo.name = "George's Lakes";
// create a table data source to access the lakes layer
dataSource = new esri.layers.TableDataSource();
dataSource.workspaceId = "MyDatabaseWorkspaceIDSSR2"; // not exposed via REST, sad face
dataSource.dataSourceName = layerName;
// and now a layer source
layerSource = new esri.layers.LayerDataSource();
layerSource.dataSource = dataSource;
dynamicLayerInfo.source = layerSource;
app.dynLyrInfos.push(dynamicLayerInfo);
// set new infos, but don't refresh
// map will be updated when the drawing options are set
app.map.getLayer("usa").setDynamicLayerInfos(app.dynLyrInfos, true);
options = [];
drawingOptions = new esri.layers.LayerDrawingOptions();
drawingOptions.renderer = new esri.renderer.SimpleRenderer(
new esri.symbol.SimpleFillSymbol(
"solid",
null,
new dojo.Color([255, 0, 255, 0.75]) // fuschia lakes!
options[4] = drawingOptions;
app.map.getLayer("usa").setLayerDrawingOptions(options);
//refresh the legend
function errorHandler(err) {
console.log("Error: ", err);
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;">
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
<div id="feedback" class="shadow">
<h3>Add and Re-order Layers</h3>
<div id="info">
<div id="hint">
Click and drag a map layer name below to re-order layers.
</div>
<strong>Map Layers</strong>
<img id="loading" src="http://dl.dropbox.com/u/2654618/loading_black.gif" />
<br />
<div id="layerList"></div>
<button id="lakes"data-dojo-type="dijit.form.Button">Add Lakes</button>
<div id="legendDiv"></div>
</div>
</div>
</div>
</div>
</body>
</html>
