Hi all,I'm adding some graphics manually to the map, with the following code:
double lat = [(NSNumber *) [colleague objectForKey: @Latitude] doubleValue];
double lon = [(NSNumber *) [colleague objectForKey: @Longitude] doubleValue];
if ( !(lat == 0.00 && lon == 0.00))
AGSSimpleMarkerSymbol *pointMarker = [AGSSimpleMarkerSymbol simpleMarkerSymbolWithColor:[UIColor orangeColor]];
pointMarker.size = 15; //[(NSNumber *) [colleague objectForKey: @Precision] intValue];
pointMarker.style = AGSSimpleMarkerSymbolStyleCircle;
AGSPoint *wgspoint = [AGSPoint pointWithX:lon y:lat spatialReference:[AGSSpatialReference spatialReferenceWithWKID:4326]];
AGSGeometry *mapPoint = [_geometryEngine projectGeometry:wgspoint toSpatialReference:self.mapView.spatialReference];
// LocationInfoTemplate * template = [[LocationInfoTemplate alloc] init];
AGSCalloutTemplate* template = [[AGSCalloutTemplate alloc] init] ;
template.titleTemplate = @${Username};
template.detailTemplate = @${TimeStamp};
AGSGraphic *location = [[AGSGraphic alloc] initWithGeometry: mapPoint
symbol: pointMarker
attributes: [colleague mutableCopy]
infoTemplateDelegate: template]; //template];
[_trackLayer addGraphic:location];
//template = Nil;
I've got the following issue.When the user taps on the graphic, the callout is supposed to be shown. But the application crashes in some SDK assembly, to be specific:0x0011bed8 <+0052> tst.w r0, #255 ; 0xffin the [AGSMapView setupCalloutUiForGraphic:mapPoint]I've tried to use my own TemplateClass (LocationInfoTemplate) and the AGSCalloutTemplate class, both had the same result.To debug this, i've added the following function:- (BOOL)mapView:(AGSMapView *)mapView shouldShowCalloutForGraphic:(AGSGraphic *)graphic {
NSLog(@Click);
return true;
Just to see what's in the Graphic object. And i was surprised:First run: _infoTemplateDelegate UIImage * 0xde9ad50Second run: _infoTemplateDelegate __NSCFNumber * 0xde9acd0I think i can say that the infoTemplate is NOT retained! What's the problem here?I'm using the 2.1 SDK, i'm using the latest Xcode (With ARC) and the latest iOS....--Edit-- Updated tot 2.2.1 SDK, same behavior.
