Hello, I'm brand new to ArcObjects SDKs and am struggling. I have a Python Add-in performing a query to select records (works great)and now trying to call the identify dialog via an .NET addin button that displays the identify dialog box to show attributes of the selected records. Below is the code I have at this point. I currently have the identify dialog displaying, but no records appearing. I know I need to input the selected records somewhere....but not sure where. Any thoughts would be appreciated. (I'm using Visual Studio/Microsoft Visual Basic 2010 and ArcGIS 10.2.1)Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.Carto
Public Class Identify_Button
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Dim pMxDoc As IMxDocument
Dim activeView As IMap
Public Sub DoIdentify(ByVal activeView As ESRI.ArcGIS.Carto.IActiveView, ByVal x As System.Int32, ByVal y As System.Int32)
pMxDoc = My.ArcMap.Application.Document
activeView = pMxDoc.FocusMap
If activeView Is Nothing Then
Return
End If
Dim map As ESRI.ArcGIS.Carto.IMap = activeView.FocusMap
Dim identifyDialog As ESRI.ArcGIS.CartoUI.IIdentifyDialog = New ESRI.ArcGIS.CartoUI.IdentifyDialogClass
identifyDialog.Map = map
'Clear the dialog on each mouse click
identifyDialog.ClearLayers()
Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
Dim display As ESRI.ArcGIS.Display.IDisplay = screenDisplay ' Implicit Cast
identifyDialog.Display = display
Dim identifyDialogProps As ESRI.ArcGIS.CartoUI.IIdentifyDialogProps = CType(identifyDialog, ESRI.ArcGIS.CartoUI.IIdentifyDialogProps) ' Explicit Cast
Dim enumLayer As ESRI.ArcGIS.Carto.IEnumLayer = identifyDialogProps.Layers
enumLayer.Reset()
Dim layer As ESRI.ArcGIS.Carto.ILayer = enumLayer.Next
Do While Not (layer Is Nothing)
identifyDialog.AddLayerIdentifyPoint(layer, x, y)
layer = enumLayer.Next()
Loop
identifyDialog.Show()
End Sub
Public Sub New()
End Sub
Protected Overrides Sub OnClick()
DoIdentify(activeView, 300, 100)
End Sub
Protected Overrides Sub OnUpdate()
Enabled = My.ArcMap.Application IsNot Nothing
End Sub
End Class
