Hi, I was previously using 10.0 on Win7 32-bit and have made the leap to 10.1 on Win7 64-bit. For some reason a script that previously ran fine is now failing when it hits a CalculateField command. The exact error message is:"ERROR 000989: Tool CalculateField cannot use VB expressions for services"import arcpy # Local variables: Strata_TSA_VRI_bk = "E:\\Projects\\FMG_WTP_Overlays.gdb\\Strata_TSA_VRI_bk" Strata_TSA_VRI_bk_Layer = "Strata_TSA_VRI_bk_Layer" Strata_TSA_VRI_bk_Layer__3_ = "Strata_TSA_VRI_bk_Layer" # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(Strata_TSA_VRI_bk, Strata_TSA_VRI_bk_Layer, "", "", "OBJECTID OBJECTID VISIBLE NONE;SHAPE SHAPE VISIBLE NONE;SISH_SEQ_NBR SISH_SEQ_NBR VISIBLE NONE;SISH_STRATUM_NAME SISH_STRATUM_NAME VISIBLE NONE;CROWN_CLOSURE CROWN_CLOSURE VISIBLE NONE;VRI_LIVE_STEMS_PER_HA VRI_LIVE_STEMS_PER_HA VISIBLE NONE;VRI_DEAD_STEMS_PER_HA VRI_DEAD_STEMS_PER_HA VISIBLE NONE;SPECIES_CD_1 SPECIES_CD_1 VISIBLE NONE;SPECIES_PCT_1 SPECIES_PCT_1 VISIBLE NONE;SPECIES_CD_2 SPECIES_CD_2 VISIBLE NONE;SPECIES_PCT_2 SPECIES_PCT_2 VISIBLE NONE;SPECIES_CD_3 SPECIES_CD_3 VISIBLE NONE;SPECIES_PCT_3 SPECIES_PCT_3 VISIBLE NONE;SPECIES_CD_4 SPECIES_CD_4 VISIBLE NONE;SPECIES_PCT_4 SPECIES_PCT_4 VISIBLE NONE;SPECIES_CD_5 SPECIES_CD_5 VISIBLE NONE;SPECIES_PCT_5 SPECIES_PCT_5 VISIBLE NONE;SPECIES_CD_6 SPECIES_CD_6 VISIBLE NONE;SPECIES_PCT_6 SPECIES_PCT_6 VISIBLE NONE;PROJ_AGE_1 PROJ_AGE_1 VISIBLE NONE;PROJ_HEIGHT_1 PROJ_HEIGHT_1 VISIBLE NONE;SHAPE_Length SHAPE_Length VISIBLE NONE;SHAPE_Area SHAPE_Area VISIBLE NONE") # Process: Select Layer By Attribute arcpy.SelectLayerByAttribute_management(Strata_TSA_VRI_bk_Layer, "NEW_SELECTION", "\"SPECIES_CD_1\" = 'FDI'") # Process: Calculate Field arcpy.CalculateField_management(Strata_TSA_VRI_bk_Layer__3_, "SPECIES_CD_1", "\"FD\"", "VB", "")
Traceback (most recent call last): File "E:\Projects\j4.py", line 22, in <module> arcpy.CalculateField_management(Strata_TSA_VRI_bk_Layer__3_, "SPECIES_CD_1", "\"FD\"", "VB", "") File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 3129, in CalculateField raise eExecuteError: Failed to execute. Parameters are not valid.ERROR 000989: Tool CalculateField cannot use VB expressions for servicesFailed to execute (CalculateField).IDLE environment: Python 2.7.2 (default, Jun 12 2011, 14:24:46) [MSC v.1500 64 bit (AMD64)] on win32Did I miss something during my installation of ArcGIS 10.1? I have used VB syntax in all my scripts and I'd rather not change everything to Python syntax.I have also tested this CalculateField command in ModelBuilder. It executes sucessfully, just failing in the Python IDLE window.Appreciate any suggestions.Thanks,Frank
