I'm trying to add a new map frame (and accompanying map) to my document's page layout. I'm roughly following the code example from this ESRI example but the process errors out withValue does not fall within the expected rangeHere is the relevant code //create the new map with settings IMap addMap = new Map(); addMap = m_maps.Create(); addMap.Name = scenarioName; IEnvelope mapExtent = new EnvelopeClass(); mapExtent = (IEnvelope)m_doc.ActiveView.Extent; //create new mapframe and set map layout IMapFrame addMapFrame = new MapFrameClass(); addMapFrame.Map = addMap; IElement mapFrameElement = (IElement)addMapFrame; IGraphicsContainer pGC = (IGraphicsContainer)m_doc.PageLayout; pGC.AddElement(mapFrameElement, 0);
It looks like the AddElement method doesn't like the integer being passed. I've tried with different int values but still get the same error. What could be causing this error?
