I'm trying to create a ClassBreakRenderer and set it on a GraphicsOvelay and cannot get it to work. The renderer works fine on a FeatureLayer, but doesn't work on a GraphicsOverlay that's been created using the same data as the FeatureLayer. I'm not sure what I'm missing here. Is there a sample somewhere that shows how to do this? I pasted the code below, and also attached the repro case, in case someone is up for giving me a hand in getting to the bottom of this. Working with 100.5. Thank you!!!
- Mara
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">RenderData</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Create a new map based on the streets base map.</SPAN>
Map newMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN>Basemap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateStreets</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create an envelope that covers the continental US in the web Mercator spatial reference.</SPAN>
Envelope continentalUSEnvelope <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Envelope</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">14193469.5655232</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2509617.28647268</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">7228772.04749191</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6737139.97573925</SPAN><SPAN class="punctuation token">,</SPAN> SpatialReferences<SPAN class="punctuation token">.</SPAN>WebMercator<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Zoom the map to the extent of the envelope.</SPAN>
newMap<SPAN class="punctuation token">.</SPAN>InitialViewpoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Viewpoint</SPAN><SPAN class="punctuation token">(</SPAN>continentalUSEnvelope<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Assign the map to the MapView.</SPAN>
MyMapView<SPAN class="punctuation token">.</SPAN>Map <SPAN class="operator token">=</SPAN> newMap<SPAN class="punctuation token">;</SPAN>
MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsOverlay</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// CHANGE THIS FLAG TO SWITCH TEST BETWEEN FEATURE LAYER AND GRAPHICS OVERLAY</SPAN>
<SPAN class="keyword token">var</SPAN> useFeatureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>useFeatureLayer<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// set feature layer and renderer and add it to the map</SPAN>
<SPAN class="keyword token">var</SPAN> featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"https://services8.arcgis.com/KsXZDThvSinzJ3pq/arcgis/rest/services/test_pipeline/FeatureServer/0"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
featureLayer<SPAN class="punctuation token">.</SPAN>Renderer <SPAN class="operator token">=</SPAN> <SPAN class="token function">CreateClassBreaksRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
MyMapView<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN>OperationalLayers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">else</SPAN>
<SPAN class="comment token">// set feature table and query it to retrieve all features</SPAN>
<SPAN class="keyword token">var</SPAN> featTable <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ServiceFeatureTable</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"https://services8.arcgis.com/KsXZDThvSinzJ3pq/arcgis/rest/services/test_pipeline/FeatureServer/0"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> queryParams <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryParameters</SPAN> <SPAN class="punctuation token">{</SPAN> WhereClause <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1=1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> featureResult <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> featTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">QueryFeaturesAsync</SPAN><SPAN class="punctuation token">(</SPAN>queryParams<SPAN class="punctuation token">,</SPAN> QueryFeatureFields<SPAN class="punctuation token">.</SPAN>LoadAll<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create graphics from the features and add them to the map in a graphics overlay</SPAN>
<SPAN class="keyword token">foreach</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> result <SPAN class="keyword token">in</SPAN> featureResult<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> pipeSegment <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>pipeSegment<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphic<SPAN class="punctuation token">.</SPAN>Attributes<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"break"</SPAN><SPAN class="punctuation token">,</SPAN> result<SPAN class="punctuation token">.</SPAN>Attributes<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"break"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>pipeSegment<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create and set renderer for the graphics overlay</SPAN>
MyMapView<SPAN class="punctuation token">.</SPAN>GraphicsOverlays<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>Renderer <SPAN class="operator token">=</SPAN> <SPAN class="token function">CreateClassBreaksRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">private</SPAN> ClassBreaksRenderer <SPAN class="token function">CreateClassBreaksRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// Create symbols</SPAN>
<SPAN class="keyword token">var</SPAN> symbol1 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbolStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">.</SPAN>Red<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> symbol2 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbolStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">.</SPAN>Yellow<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> symbol3 <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbolStyle<SPAN class="punctuation token">.</SPAN>Solid<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">.</SPAN>Green<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Create class breaks</SPAN>
List<SPAN class="operator token"><</SPAN>ClassBreak<SPAN class="operator token">></SPAN> listClassBreaks <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">List</SPAN><SPAN class="operator token"><</SPAN>ClassBreak<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClassBreak</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> symbol1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClassBreak</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> symbol2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClassBreak</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"3"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> symbol3<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">// Create and return the a class break renderer for use with the "break" field</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClassBreaksRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"break"</SPAN><SPAN class="punctuation token">,</SPAN> listClassBreaks<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
