Good morning. Can anyone assist with the code below? I am trying to initially show a Choropleth map and then allow the user to use the TimeSlider object to view data on the thematic map over time. Is something awry in my code below?
| var map; |
| var yr; |
| var whereclause; |
| var symbol; |
require([
"esri/map", "esri/layers/FeatureLayer","esri/layers/ArcGISDynamicMapServiceLayer","esri/layers/ImageParameters"
| | ,"esri/tasks/QueryTask","esri/tasks/query","dojo/number", "esri/symbols/TextSymbol", |
"esri/InfoTemplate", "esri/symbols/SimpleFillSymbol", "esri/geometry/Extent", "esri/layers/LabelLayer",
| | | "esri/tasks/GeometryService","esri/geometry/Point","esri/tasks/AlgorithmicColorRamp", |
"esri/renderers/ClassBreaksRenderer","esri/tasks/GenerateRendererParameters", "esri/tasks/GenerateRendererTask",
| | "esri/symbols/SimpleMarkerSymbol","esri/symbols/SimpleLineSymbol","esri/renderers/SimpleRenderer", "esri/TimeExtent", |
| | "esri/dijit/TimeSlider", "dojo/_base/array", "esri/tasks/ClassBreaksDefinition", |
"esri/Color", "esri/dijit/Legend", "dojo/dom", "dojo/dom-construct", "dojo/dom-style", "dojo/domReady!"
], function(
Map, FeatureLayer,ArcGISDynamicMapServiceLayer, ImageParameters, QueryTask, Query, number, TextSymbol,
InfoTemplate, SimpleFillSymbol, Extent, LabelLayer, GeometryService, Point, AlgorithmicColorRamp,
ClassBreaksRenderer,GenerateRendererParameters, GenerateRendererTask,SimpleMarkerSymbol,SimpleLineSymbol,SimpleRenderer,
| | TimeExtent, TimeSlider, arrayUtils, ClassBreaksDefinition, Color, Legend, dom, domConstruct, domStyle |
| | yr = 2013; |
| | whereclause = "xyz"; |
| | symbol = new SimpleFillSymbol(); |
symbol.setColor(new Color([150, 150, 150, 0.5]));
map = new Map("mapDiv", {
//basemap: "streets",
//center: [-98.215, 38.382],
//zoom: 10
//slider: false//,
| | //extent: bbox |
| | showAttribution: false, |
| | logo: false |
| | var imageParameters = new ImageParameters(); |
imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
//Takes a URL to a non-cached map service.
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("mapserviceurl", {
"opacity" : 0.5,
"imageParameters" : imageParameters
| | var infoTemplate = new InfoTemplate(); |
| | infoTemplate.setTitle("${field1}"); |
| | infoTemplate.setContent("Data Value: ${field2}"); |
var featureLayer = new FeatureLayer("featurelayerurl", {
mode: FeatureLayer.MODE_SNAPSHOT,
outFields: ["*"],
infoTemplate: infoTemplate
| | showMap(yr); |
| | function showMap(yrselected) | { |
| | | 'use strict;' |
| | createRenderer("field2"); |
| | function createRenderer(field2) { |
| | | 'use strict;' |
| | | var classDef = new ClassBreaksDefinition(); |
| | | classDef.classificationField = "field2"; |
| | | classDef.classificationMethod = "quantile"; |
| | | classDef.breakCount = 4; |
| | | classDef.baseSymbol = symbol; |
| | | var colorRamp = new AlgorithmicColorRamp(); |
| | | colorRamp.fromColor = new Color.fromHex("#F0F9E8"); |
| | | colorRamp.toColor = new Color.fromHex("#2B8C5A"); |
| | | colorRamp.algorithm = "hsv"; |
| | | classDef.colorRamp = colorRamp; |
| | | var params = new GenerateRendererParameters(); |
| | | params.classificationDefinition = classDef; |
| | | params.formatLabel = true; |
| | | // limit the renderer to data being shown by the feature layer |
| | | params.where = whereclause; |
| | | var generateRenderer = new GenerateRendererTask("featurelayerurl"); |
| | | generateRenderer.execute(params, applyRenderer, showErr); |
| | function applyRenderer(renderer) { |
| | | 'use strict;' |
| | | featureLayer.setDefinitionExpression(whereclause); |
| | | renderer.defaultSymbol = symbol; |
| | | renderer.defaultLabel = "Data unavailable"; |
| | | renderer.isMaxInclusive = false; |
| | | featureLayer.setRenderer(renderer); |
| | | featureLayer.redraw(); |
| | | // define State labels (from feature layer field) |
| | | var labelField = "labelfield"; |
| | | var statesColor = new Color("#000000"); |
| | | var statesLabel = new TextSymbol().setColor(statesColor); |
| | | statesLabel.font.setSize("11pt"); |
| | | statesLabel.font.setFamily("Lato,'Helvetica Neue',Helvetica,Arial,sans-serif"); |
| | | var statesLabelRenderer = new SimpleRenderer(statesLabel); |
| | | var labels = new LabelLayer({ id: "labels" }); |
| | | // associate feature layer and label layer |
| | | labels.addFeatureLayer(featureLayer, statesLabelRenderer, "{" + labelField + "}"); |
| | | //getInfoFromRenderer(renderer); |
| | | //createLegend(); |
| | | // add all layers to the map |
| | | // dynamicMapServiceLayer servers as base layer |
| | | // featureLayer has data to be visualized |
| | | // labels has labels for geographic boundaries on the featuer layer |
| | | map.addLayers([dynamicMapServiceLayer, featureLayer, labels]); |
| | | map.on("layers-add-result", initSlider); |
| | function showErr(err){ |
| | | 'use strict;' |
| | | | console.log(err); |
| | function formatValues(num) { |
| | | 'use strict;' |
return number.format(num, { "places": 1 });
| | function initSlider() { |
| | | 'use strict;' |
| | | var timeSlider = new TimeSlider({ |
| | | | style: "width: 100%;" |
| | | }, dom.byId("timeSliderDiv")); |
| | | map.setTimeSlider(timeSlider); |
| | | var timeExtent = new TimeExtent(); |
| | | timeExtent.startTime = new Date("1/1/1993 UTC"); // get from data |
| | | timeExtent.endTime = new Date("12/31/2010 UTC"); // get from data |
| | | timeSlider.setThumbCount(1); |
| | | timeSlider.createTimeStopsByTimeInterval(timeExtent, 1, "esriTimeUnitsYears"); |
| | | timeSlider.setThumbIndexes([0]); |
| | | timeSlider.setThumbMovingRate(7000); |
| | | timeSlider.startup(); |
| | | //add labels for every other time stop |
| | | var lbls = arrayUtils.map(timeSlider.timeStops, function(timeStop, i) { |
| | | | if ( i % 2 === 0 ) { |
| | | | return timeStop.getUTCFullYear(); |
| | | | } else { |
| | | | return ""; |
| | timeSlider.setLabels(lbls); |
| | timeSlider.on("time-extent-change", function(evt) { |
var startValString = evt.startTime.getUTCFullYear();
var endValString = evt.endTime.getUTCFullYear();
dom.byId("daterange").innerHTML = "<i>" + startValString + " and " + endValString + "<\/i>";
| | | yr = endValString; |
| | | //showMap(yr); |
Does anyone have an example of a choropleth map playing over time?
Thanks.
