Trying to replace a null value with the field calculator. I am have a script that appends multiple feature classes into one feature class. After each feature class appends I want to add a field calculateField_management (field calculator) statement run that makes all null values from a specific field into a string value.
I've tried a number of ways but have yet to get an expected result.
I have 2 values for in the field - Null, 'CFW' and need to replace Null with 'TAR'.
Then I will have 3 values - Null, 'CFW', 'TAR' and will need to replace Null with 'DEN'
I've been trying something along the lines of:
def myCalc(x)
if (x != 'CFW"):
return 'TAR'
else:
return 'CFW'
Should be simple but I haven't had much luck getting the expected response. Could use help on both field calculations.
-Keith
