I Can publish a Sever blow: but "Single Fused Map Cache" is false. it's not a wmts Server.
IServerObjectAdmin pServerObjectAdmin;
pServerObjectAdmin = ConnectAGS("http://localhost:6080/arcgis/admin", "arcgis", "79");
IServerObjectConfiguration2 configuration = (IServerObjectConfiguration2)pServerObjectAdmin.CreateConfiguration();
IEnumServerObjectConfiguration ss = pServerObjectAdmin.GetConfigurations();
IServerObjectConfiguration2 pp;
for (int i = 0; i < ss.Count; i++)
pp = (IServerObjectConfiguration2)ss.Next();
String name = pp.Name;
if (name == servername)
return;
configuration.Name = servername;
configuration.TypeName = "MapServer";
IPropertySet props = configuration.Properties;
props.SetProperty("FilePath", filepath);
object names, values;
props.GetAllProperties(out names, out values);
props.SetProperty("OutputDir", @F:\arcgisserver\directories\arcgisoutput);
string VirtualOutPutDir = "/rest/directories/arcgiscache";
props.SetProperty("VirtualOutPutDir", VirtualOutPutDir);
props.SetProperty("SupportedImageReturnTypes", "URL");
props.SetProperty("MaxImageHeight", "2048");
props.SetProperty("MaxRecordCount", "500");
props.SetProperty("MaxBufferCount", "100");
props.SetProperty("MaxImageWidth", "2048");
props.SetProperty("outputDir", @F:\\arcgisserver\\directories\\arcgisoutput);
props.SetProperty("isCached", "true");//
props.SetProperty("minScale", "500000"); //
props.SetProperty("tilingScheme", "3");//
props.SetProperty("maxScale", "32000");//
//props.SetProperty("CacheOnDemand", "true");//
props.SetProperty("IgnoreCache", "false");//
props.SetProperty("antialiasingMode", "None");//
props.SetProperty("ClientCachi@ngAllowed", "true");
props.SetProperty("CacheDir", "F:\\arcgisserver\\directories\\arcgiscache");--------------------------------------------------------------------------------------------------------------------------------------------
configuration.set_ExtensionEnabled("WMServer", true);
IPropertySet wmsprops = configuration.get_ExtensionProperties("WMServer");
How do I set up properties?
Thank you for your helper.
