I am trying to code a widget that edits the symbology of an output map service.
I have a widget that works using a predefined path, so that part im ok with: e.g. mapservice/0
I need to somehow run a Geoprocessing Tool, then pass the jobid/mapservice/0 to my existing widget. (Or write a new widget, whatever is required!)
Does anyone have any ideas how this should be accomplished? Maybe I just need to get the output JobID into a javascript variable and can work it out from there, does the geoprocessing widget emit any events?
Possibly these threads are relevant but im not sure:
Using result map service in web applications—ArcMap | ArcGIS Desktop
Send a layer to the Attribute Table widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
