I have built an application using the Story Map Series with nine tabs. It works fine on IE, Chrome and Firefox, but when I try to view it on an iPad (running iOS 10.3.3) the app initially loads, but as soon as a different tab is selected I get the following error "A problem occurred with this webpage so it was reloaded". The app reloads at the default tab. After several attempts I get the message "A problem repeatedly occurred on "[url]". I've tried using the tabbed, side accordion, and bulleted layout options, but get the same behavior with each layout. We have other apps built on this template that work fine on this same iPad, but they have fewer maps. Are there known limitations with number of tabs for this template on iOS? Any thoughts or suggestions?
