Hi guys,
I am having a set of LAZ files downloaded from a Government website, converted them into LAS using 3D Sample tools (https://www.arcgis.com/home/item.html?id=fe221371b77940749ff96e90f2de3d10) and tried to load it into ArcGIS pro by creating a LAS Dataset. I used the UTM projection of the region(Rotterdam, Netherlands). When I am adding the Las Dataset into the Scene I am getting it near by Africa instead of Europe. I couldn't able to find out the problem, the problem is with projection I used the projection tools given in the 3D Sample tolls but nothing changed the result. When I didn't give any coordinate system the data is coming in North America.
Kindly help me to narrow down the issue and what other tools can be tested with the data?
