The BUFF_DIST field is not being populated and i am not sure why. Can some one explain to me what i am doing wrong please?
Current code.
import arcpy, os
mxd = arcpy.mapping.MapDocument("CURRENT")
lyr = arcpy.mapping.ListLayers(mxd, "SUBJECT_PROPERTY")[0]
#lyrpath = lyr.workspacePath
arcpy.env.workspace = os.path.dirname(mxd.filePath)
wp = os.path.dirname(mxd.filePath)
try:
SP = "SUBJECT_PROPERTY"
lyr.replaceDataSource(wp, "SHAPEFILE_WORKSPACE", SP, True )
except:
pass
try:
if arcpy.ListFields(SP, "BUFF_DIST"):
print "Field exists"
else:
arcpy.AddField_management("SUBJECT_PROPERTY","BUFF_DIST","Double")
except:
pass
arcpy.RefreshActiveView()
arcpy.RefreshTOC()
distances = ["2 Mile", "1 Mile"]
for distance in distances:
outfile = "wp%s" % distance
arcpy.Buffer_analysis(SP, outfile, distance, "OUTSIDE_ONLY", "ROUND", "", "BUFF_DIST")<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>i tried to use the arcpy.da.UpdateCursor to update the BUFF_DIST field of the new feature classes but on the the first one gets populated.
Code with arcpy.da.UpdateCursor
import arcpy, os
try:
except:
pass
try:
else:
except:
pass
arcpy.RefreshTOC()
with arcpy.da.UpdateCursor("wp%s" % distance, "ToBufDist") as cursor:
for row in cursor:
if row[0] in (""," ",None):
row[0] = '1'
cursor.updateRow(row)
else:
pass
for row in cursor:
row[0] = '2'
else:
pass
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
