I use android 100.1.0 and I try to load a mmpk file in android.
I see my map but it is empty no layers visibled !!
What's the problem ?
I don't understand ...
// create the mobile map package
mapPackage = new MobileMapPackage(mmpkFile);
// add done listener which will invoke when mobile map package has loaded
mapPackage.addDoneLoadingListener(new Runnable() {
@Override
public void run() {
// check load status and that the mobile map package has maps
if(mapPackage.getLoadStatus() == LoadStatus.LOADED && mapPackage.getMaps().size() > 0){
Log.e(TAG, "***************** SUCCESS CHARGEMENT MMPK ********************");
// add the map from the mobile map package to the MapView
ArcGISMap map = mapPackage.getMaps().get(0);
if (map != null){
_mapView.setMap(map);
map.addDoneLoadingListener(
Log.e(TAG, "******************************** Carte chargée");
map.getOperationalLayers().stream().forEach(layer -> {
if (layer.getLoadStatus() != LoadStatus.LOADED && layer.getLoadStatus() != LoadStatus.LOADING)
// On force le chargement de tous les layers
layer.loadAsync();
Log.e(TAG, "******************************** Chargement du layer " + layer.getName());
map.loadAsync();
else{
}else{
// Log an issue if the mobile map package fails to load
Log.e(TAG, mapPackage.getLoadError().getMessage());
// load the mobile map package asynchronously
mapPackage.loadAsync();
Thanks for you help
