I'd like to create a custom print service that uses a report template configured to pull the results of the Public Notification widget in one of our ArcGIS Online apps. I'd like to pull the value used as the "Search Distance" and one or 2 fields from the "Subject" feature as the header, and then a table of the parcels that intersect the buffer with several of their attributes.
In this image, the orange property would be the subject, and the blue properties would be the intersecting features.
I have created a Report in ArcGIS Pro, set up the look the way I want it and got the table to pull values from a selection I did in a Pro map. Right now the header data is all plain text except the dynamic date. I'm hoping it is possible to use tags or something to pull the necessary values from the Public Notification widget.
I am hoping this can be done without needing Developer Edition of Web AppBuilder, but am open to trying it out.
