So I have freshly installed GeoEvent extension to a ArcGIS 10.5 Server with some registered ArcGIS server connections. One of the connections require username and password. When I try to use that (successfully added) server connection in a field enricher, this error can be found in the stacktrace.. (slightly cut for readability)
com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection | Key file does not exist. java.lang.Exception: Key file does not exist. at com.esri.ges.security.cryptography.internal.GeoEventServerCryptoImpl.doDecrypt(GeoEve.... com.esri.ges.processor.fieldenricher.FeatureServiceDataProvider...... |
com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection | Error trying to decrypt Web Tier Password. | |
I can also see some zookeeper issues in the log. Maybe the keyfile are stored in zookeeper and it all fails because of this?
| org.apache.curator.framework.state.ConnectionStateManager | State change: RECONNECTED |
| com.esri.ges.fabric.internal.ZKPersistenceUtility | KeeperErrorCode = ConnectionLoss for /geoevent/config/clusters/default/arcgisServerConnections/ff2006f0-c141-4150-8ace-d183fa6c5d59.json/ServicesCache.json org.apache.zookeeper.KeeperException$ConnectionLossException: KeeperErrorCode = ConnectionLoss for /geoevent/config/clusters/default/arcgisServerConnections/ff2006f0-c141-4150-8ace-d183fa6c5d59.json/ServicesCache.json at org.apache.zookeeper.KeeperException.create(KeeperException.java:99)[23:org.apache.zookeeper.zookeeper-geoevent:3.5.0] at o |
| org.apache.curator.ConnectionState | Connection string changed to: EEARCGISTEST01.EIDSIVAENERGI.NO:2181 |
What am I missing?
