Hello everyone,I am trying to add a dotted line to mi map, and the code I am using is the following:
//Define a polyline between the two given points
IPolyline polyline = new PolylineClass();
polyline.FromPoint = from_point;
polyline.ToPoint = to_point;
//Define the color of the line (black)
IRgbColor colorEsri = new RgbColorClass();
colorEsri.Red = color.R;
colorEsri.Green = color.G;
colorEsri.Blue = color.B;
//Create the final simple line, setting its properties
ISimpleLineSymbol simpleLineSymbol = new SimpleLineSymbol();
simpleLineSymbol.Color = colorEsri;
simpleLineSymbol.Style = lineStyle;
simpleLineSymbol.Width = width;
//Create abd set the element that will contain the defined line
//It's geometry will be the one of the polyline
ILineElement element = new LineElementClass();
element.Symbol = simpleLineSymbol as ILineSymbol;
IElement lineElement = (IElement)element;
lineElement.Geometry = (IGeometry)polyline;
When I add the line to the map, it is drawn correctly. But there is one case in which this is not working properly: if "lineStyle" is esriSimpleLineStyle.esriSLSDot and "width" is greater than 1, the line is not dotted, but a normal line. However, if "width" is equal to 1, then the line is perfectly dotted.Does anyone know why I cannot create a dotted line with a width greater than 1?Thank you very much in advance.
