I am trying to use URL parameters to execute a search with the Query widget, but am having trouble getting the widget to see the url correctly. when I try and use the built in 'query' parameter, no matter what id I use I get an 'invalid id' message in the console. I am very unclear as to what id it is asking for since the layer id I am trying to query on isn't some long integer, at least not that I can find. The layer id in the config file is the 'name' of the layer, which doesn't work, and if I try using the id from the REST service json page for the layer, that doesn't work either. Do I have to generate the id somehow?
This url throws invalid id error
https://ocean.floridamarine.org/InDevelopment/GA_WebProjects/WMA_Entrances/WMA_EntranceFinderWAB2.13_sandbox1/?query=WMA%20Entrances%20Florida,NAME_ENT,Andrews%20WMA<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
This url seems to work, no error.
https://ocean.floridamarine.org/InDevelopment/GA_WebProjects/WMA_Entrances/WMA_EntranceFinderWAB2.13_sandbox1/?WMA%20Entrances%20Florida,NAME_ENT,Andrews%20WMA<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Aside from the id question, is there an advantage to using the 'query' parameter? Are there any limitations in not using it? I am still able to extract the parameters in the widget.js file using both jimuUtils.urlToObject() method and getUrlParams() method.
I have already looked at the esri docs, but am still confused!
Use URL parameters—Web AppBuilder for ArcGIS | Documentation
URL query parameters in Web AppBuilder — CommunityHub
Thanks for any clarifications
