I understand that TLS 1.2 is a protocol for HTTPS. ESRI states that "After April 16, 2019, ArcGIS Online services will only accept connections using TLS 1.2." Does imply that AGOL will no longer allow incoming HTTP connections and will require all map services to be HTTPS? For example, if I have a local ArcGIS Server publishing map services to AGOL using HTTP, those connections will be rejected after April 16th 2019 unless they are HTTPS?
