I have a layer of country polygons that I am color-coding based on dynamic metrics. My problem is not one of functionality but performance - the country polygons are requeried every time I want to change the color-coding symbols (fill color) associated with them.The layer is created with code like this:
var countryLayer = new esri.layers.FeatureLayer(urltools.fixServerURL(layerInfo.url), {
mode: esri.layers.FeatureLayer.MODE_ONDEMAND, // neither ONDEMAND nor SNAPSHOT works as I'd like
// mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
opacity: 0.75,
outFields: ["*"] });
When I want to update the map to change the color-coding of countries, after some computation I assign new symbols with code like this:
// Go thru all countries, computing the color for each and changing its symbol
for (var ic = 0; ic < mapLayers.countryCodeList.length; ic++) {
var ccode = mapLayers.countryCodeList[ic];
var csym = csymNoData;
var val = mapData.currDataView.cntryVals[ccode]
var index = _getRangeIndexForData(val);
if (index >= 0)
csym = options.cranges[index].csym;
// console.log("cntry: " + ccode + " val: " + cntryVals[ccode] + " color: " + csym.r + "," + csym.g + "," + csym.b);
mapLayers.countrySymbols[ccode] = new esri.symbol.SimpleFillSymbol().setColor(csym);
mapLayers.renderer.removeValue(ccode);
mapLayers.renderer.addValue({value: ccode, symbol: mapLayers.countrySymbols[ccode],
label: "Label: " + ccode, description: "Description: " + ccode});
Nothing is updated unless I call refresh(), but that causes a refetch over the internet tubing:
mapLayers.countryLayer.refresh();
Is there a way for me to dynamically update the country colors without continually refetching the same unchanging boundary data?Thanks,Rex BradfordDirect Relief International
