Hello, i have the following script and im getting an error 1060 that goes like this:
{"addResults":[{"success":false,"error":{"code":1060,"description":"Rowbuffer creation failed."}}],"updateResults":[],"deleteResults":[]} error
What im doing wrong?
My script to add a new feature using ajax.
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">agregarFact</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">,</SPAN> callback<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>aaa
<SPAN class="keyword token">var</SPAN> myAttributes <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
Rut <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"1231556165-5"</SPAN><SPAN class="punctuation token">,</SPAN>
Nombre <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">,</SPAN>
Apellido <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"b"</SPAN><SPAN class="punctuation token">,</SPAN>
Telefono <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"84031822"</SPAN><SPAN class="punctuation token">,</SPAN>
Email<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-email-small" href="mailto:aa@aa.CL" rel="nofollow noopener noreferrer" target="_blank">aa@aa.CL</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
Tipo_cliente <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"INDUSTRIAL"</SPAN><SPAN class="punctuation token">,</SPAN>
Tipo_contribuyente <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"AUTOCONSUMO"</SPAN><SPAN class="punctuation token">,</SPAN>
Rotulo <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"131551077"</SPAN><SPAN class="punctuation token">,</SPAN>
Tramo <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"CD35-CD35-CD35"</SPAN><SPAN class="punctuation token">,</SPAN>
Empalme <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SUBTERRANEO"</SPAN><SPAN class="punctuation token">,</SPAN>
Fase <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"TRIFASICO"</SPAN><SPAN class="punctuation token">,</SPAN>
Potencia <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6.0</SPAN><SPAN class="punctuation token">,</SPAN>
Capacidad_empalme <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6.6</SPAN><SPAN class="punctuation token">,</SPAN>
Capacidad_interruptor <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN>
Tiempo_empalme <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"DEFINITIVO"</SPAN><SPAN class="punctuation token">,</SPAN>
Tipo_empalme<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"BT"</SPAN><SPAN class="punctuation token">,</SPAN>
Cantidad_empalme <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN>
ID_Direccion <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4855875</SPAN><SPAN class="punctuation token">,</SPAN>
Direccion<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"AVENIDA ARGENTINA 1"</SPAN><SPAN class="punctuation token">,</SPAN>
Potencia_calculada <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18</SPAN><SPAN class="punctuation token">,</SPAN>
DistRotuloMedidor<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN>
DistDireccionMedidor <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">22</SPAN><SPAN class="punctuation token">,</SPAN>
Comuna <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"VALPARAISO"</SPAN><SPAN class="punctuation token">,</SPAN>
Alimentador<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"BARON"</SPAN><SPAN class="punctuation token">,</SPAN>
Idnodo <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">131551077</SPAN><SPAN class="punctuation token">,</SPAN>
Estado_tramite<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"NUEVA"</SPAN><SPAN class="punctuation token">,</SPAN>
Tipo_factibilidad<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"FACTIBILIDAD ASISTIDA"</SPAN><SPAN class="punctuation token">,</SPAN>
Tipo_mejora <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
Zona <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ZONA VALPARAISO"</SPAN><SPAN class="punctuation token">,</SPAN>
Origen_factibilidad <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OFICINA COMERCIAL"</SPAN><SPAN class="punctuation token">,</SPAN>
Sed <SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
PotenciaDispSed <SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">325.27305331396866</SPAN>
<SPAN class="punctuation token">}</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>myAttributes<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> geox <SPAN class="operator token">=</SPAN> f<SPAN class="punctuation token">.</SPAN>factigisGeoCliente<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> geoy<SPAN class="operator token">=</SPAN> f<SPAN class="punctuation token">.</SPAN>factigisGeoCliente<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> data <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
f<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'json'</SPAN><SPAN class="punctuation token">,</SPAN>
adds<SPAN class="punctuation token">:</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN> attributes<SPAN class="punctuation token">:</SPAN> myAttributes<SPAN class="punctuation token">,</SPAN> geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN>geox <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> geoy<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
token<SPAN class="punctuation token">:</SPAN> token<SPAN class="punctuation token">.</SPAN><SPAN class="token function">read</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
jQuery<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ajax</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
method<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'POST'</SPAN><SPAN class="punctuation token">,</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fmyserver%2Farcgis%2Frest%2Fservices%2FFACTIBILIDAD%2FFACTIGIS%2FFeatureServer%2F0%2FapplyEdits" target="_blank">http://myserver/arcgis/rest/services/FACTIBILIDAD/FACTIGIS/FeatureServer/0/applyEdits</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
dataType<SPAN class="punctuation token">:</SPAN><SPAN class="string token">'html'</SPAN><SPAN class="punctuation token">,</SPAN>
data<SPAN class="punctuation token">:</SPAN> data
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">done</SPAN><SPAN class="punctuation token">(</SPAN>d <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">.</SPAN><SPAN class="token function">includes</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"error"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"error"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">callback</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">.</SPAN><SPAN class="token function">includes</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"success"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"adds"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">callback</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">fail</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"no pase"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
