I have 2 dictionaries (A and
. A is a new list of keys which is being checked against B. If a key is in B but not A (is an old value), I'm attempting to get the first value from the associated key in the dictionary (in this case an OBJECTID).
The issues I'm having are with line 32. As far as I can tell, this should iterate through all the keys in B, see if they're in A, and if not, write their value to a text file. As it happens, the text file is just getting the full list of old values (dictionary
instead of only the ones not in both feature classes/dictionaries. Where are we going wrong?
I've attached the output text file
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="comment token"># Set environmental variables</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
new <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"W:\Mapping\ArcGIS Online\ArcGIS Online Features.gdb\Collector_patch"</SPAN> <SPAN class="comment token">#new feature class</SPAN>
old <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"W:\Mapping\ArcGIS Online\Upload.gdb\AGOL_Export"</SPAN> <SPAN class="comment token">#old feature class</SPAN>
field <SPAN class="operator token">=</SPAN> <SPAN class="string token">'LinkKey'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'OBJECTID'</SPAN> <SPAN class="comment token">#feature class fields to compare & return</SPAN>
fout <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"W:\Mapping\ArcGIS Online\FPC Plantations Features to Delete.txt"</SPAN> <SPAN class="comment token">#output text file</SPAN>
a <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
b <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">#The old feature class is loaded into dictionary b</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>old<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> rows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> rows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> b<SPAN class="punctuation token">:</SPAN>
b<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#The new feature class is loaded into dictionary a</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>new<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> rows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">:</SPAN>
a<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#Below compares the dictionaries and extracts features with old Linkkeys"</SPAN>
fo <SPAN class="operator token">=</SPAN> open<SPAN class="punctuation token">(</SPAN>fout<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"w"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> k<SPAN class="punctuation token">,</SPAN> v <SPAN class="keyword token">in</SPAN> b<SPAN class="punctuation token">.</SPAN>iteritems<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> k <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> k
<SPAN class="keyword token">print</SPAN> v
fo<SPAN class="punctuation token">.</SPAN>write<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">(</SPAN>v<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">','</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Linkkeys not in new feature class exported"</SPAN>
fo<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
