dlv<SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> `<SPAN class="operator token"><</SPAN>b<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">'name_plc'</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>b<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN>ID<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"ida"</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>feature<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN> URL<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token"><</SPAN>a href<SPAN class="operator token">=</SPAN><SPAN class="string token">"${feature.graphic.attributes.url}"</SPAN> target<SPAN class="operator token">=</SPAN><SPAN class="string token">"_blank"</SPAN><SPAN class="operator token">></SPAN>View<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>a<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN> Updated<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">'tiCon1'</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>feature<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>updated<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN>Grid_value<SPAN class="punctuation token">:</SPAN> $<SPAN class="punctuation token">{</SPAN>feature<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>grid_value<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN>br<SPAN class="operator token">></SPAN> Event Time<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token"><</SPAN>span <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">'tiCon2'</SPAN><SPAN class="operator token">></SPAN>$<SPAN class="punctuation token">{</SPAN>feature<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>eventTime<SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN><SPAN class="punctuation token">.</SPAN>esri<SPAN class="operator token">-</SPAN>popup__navigation <SPAN class="punctuation token">{</SPAN> display<SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>`<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> date1<SPAN class="operator token">=</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'.tiCon1'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">text</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> dt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Date</SPAN><SPAN class="punctuation token">(</SPAN>date1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toUTCString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>dt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I try the above to convert it, for instance and it consoles as invalid date...
In the above, my event time and updated queries resolve as the numbers below.. I want to convert these to a human readable format.
Updated: 1593543128000 <---------------------
Event Time: 1593021559000 <----------------------------
