i have used this script to call a Map Service an retrivethe geometry:
URL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fserver%2Farcgis%2Frest%2Fservices%2Fservices%2FMapServer%2F0%2Fquery" target="_blank">http://server/arcgis/rest/services/services/MapServer/0/query</A><SPAN>"</SPAN></SPAN>
where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"1=1"</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="string token">"*"</SPAN>
query <SPAN class="operator token">=</SPAN> <SPAN class="string token">"?where={}&outFields={}&returnGeometry=true&f=json"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>where<SPAN class="punctuation token">,</SPAN> fields<SPAN class="punctuation token">)</SPAN>
fsURL <SPAN class="operator token">=</SPAN> URL <SPAN class="operator token">+</SPAN> query
fs <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>FeatureSet<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
fs<SPAN class="punctuation token">.</SPAN>load<SPAN class="punctuation token">(</SPAN>fsURL<SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Now i need to request this service with POST method by REST folder and pass it InpputGeometry with Spatial Relationship, so i can load only a subset of data. How i can do this?
There is some example?
