I am working with the Data reviewer to run monthly checks on our data. I am struggeling to understand how the Composite check works, espcially in combination with the *Not option. I hope someone has more experience with this check and can help clarify how it works.
For example, if I have two line feature classes (A,
and 1 polygon feature class (C) and I would like to get the following result:
Lines of FC A that do not intersect (in the form of line, relation: 1********) with lines of FC B (check 1) and are also not within polygons of FC C (check 2). In the results I still see lines of FC A that intersect with FC B, so it probably does not work the way I think it works.
Can someone help explain how this check works?
Thank you!
