I am looking for some general recommendations on which set of files to use when generating a mosaic dataset. We have 3 inch, county wide imagery in two different formats...
- 1 folder containing 5 MrSID files ranging from 7gb to 36 gb in size
- 1 folder containing 11,709 TIF files that around 155 mb each in size
I originally created a mosaic dataset using scripts and workflow from Managing Preprocessed Orthophotos. Going through the workflow would have created more than 22,000 overviews with the MrSID files. Not sure if this is an excessive amount of overviews or not. If I do not Force Overview Tiles, only 6 overviews are created.
I am thinking that maybe using the the smaller TIF files may be the way to go. I wanted to ask before I went too far down the rabbit hole.
The end goal will be serving up the imagery as an image services basemap. We are using 10.7.1 Enterprise with the Image Server extension
Thanks for your help!
