I'm developing an UWP solution using 100.2.0 .NET Runtime and I should display some military tactical graphics on a map.
I'm trying to use mil2525c.stylx with this code:
DictionarySymbolStyle symbolDictionary = await DictionarySymbolStyle.OpenAsync("mil2525c", installedLocation.Path + @\Assets\mil2525c.stylx) as DictionarySymbolStyle;
Running application it shows this error:
File not found: Failed to create Rule Engine: mil2525c
I noticed that that method only accepts "mil2525c_b2" as specification type but it doesn't render any tactical graphics.
The only way I was able to make it render some tactical graphics is using
DictionarySymbolStyle symbolDictionary = await DictionarySymbolStyle.OpenAsync("mil2525c_b2", installedLocation.Path + @\Assets\mil2525c_b2.stylx) as DictionarySymbolStyle;
Frankly I don't understand the relationship between specification type parameter and *.stylx file.
Is specification type related to military standard?
Is there a list of valid values for every *.stylx file (for example, I would like to know the correct specification type related to the "app6b.stylx")
Thanx in advance.
Mauro
