Hi,We just upgraded from ArcEngine 10 to 10.1 and now the raster calculator does not seem to work anymore.Whenever I execute the geoprocesing tool, we get a LoaderLock was detected error and we are unable to continue.If I turn off the Loader Lock exception in Visual Studio, it get's a bit further and the application throws a C++ Runtime Error R6034 (Application has made an attempt to load the C run time library incorrectly).If I check the geoprocessing message logs I see a ERROR 000539: Runtime error (AttributeError: 'geoprocessing sys.stdout object' object has no attribute 'write')When I try to run the same thing in ArcMap's Raster Calculator it works fine.Any idea what going on? Thanks.NiroI'm using the following code to execute the raster calculator: String expression = @'C:\Temp\RasterCalc\dem_pre' * 10;
String outputPath = @C:\Temp\FloodPlain24;
Geoprocessor processor = new Geoprocessor();
RasterCalculator RasterCalc = new RasterCalculator(expression, outputPath);
FileInfo fileInfo = new FileInfo(outputPath);
try
if (!fileInfo.Directory.Exists) fileInfo.Directory.Create();
processor.OverwriteOutput = true;
processor.Execute(RasterCalc, null);
catch (Exception ex)
Debug.Assert(false, ex.ToString());
Debug.Write(GetMessages(processor));
The full geoprocessing log is as follows:Executing: RasterCalculator "'C:\Temp\RasterCalc\dem_pre' * 10" C:\Temp\FloodPlain24
Start Time: Wed Apr 03 09:52:45 2013
Raster(r'C:\Temp\RasterCalc\dem_pre') * 10
File "C:\Python27\ArcGIS10.1\Lib\warnings.py", line 29, in _show_warning
file.write(formatwarning(message, category, filename, lineno, line))
Failed to execute (RasterCalculator).
Failed at Wed Apr 03 09:54:26 2013 (Elapsed Time: 1 minutes 41 seconds)
