I have been developing simple mapping applications for a couple of years now using legacy code and am in the process of making the transition over to AMD. However, I seem to be having trouble grasping the concept of the AMD modules and how they relate to overall scope and other functions in the application. As an example, I have posted the JavaScript code from two simple query applications below, one in legacy, and the other as my attempt at creating the same application in AMD. The legacy works properly, however the AMD version gives me errors with being able to find the QueryTask. Could someone take a look and direct me to where I am going wrong? Or point me to a good resource that explains the best way of learning AMD from legacy code? I understand the legacy code well but am having a great deal of trouble figuring out the advantage of switching over to AMD. Thanks in advance.Legacy:dojo.require("esri.tasks.query"); dojo.require("esri.map"); var map, countyQuery, countyQueryTask; function init(){ //set map properties var startExtent = new esri.geometry.Extent ({"xmin":-9132004.21177897, "ymin":3780378.56383079, "xmax":-8618716.31271849, "ymax":4021468.33460162, "spatialReference":{wkid:102100}}); map = new esri.Map("map",{ center: [-80.94, 33.646], basemap: "streets", extent:startExtent, }); } function zoomTocounty(county){ map.graphics.clear(); var cntyName = document.getElementById("txtSearch").value; countyQueryTask = new esri.tasks.QueryTask("MYSERVICEHERE"); countyQuery = new esri.tasks.Query(); countyQuery.returnGeometry = true; countyQuery.where = "NAME"+'='+"'"+cntyName+"'"; countyQueryTask.execute(countyQuery,ZoomTocountyGeometry) } function ZoomTocountyGeometry(featureSet){ if(featureSet.features.length > 0){ var graphic =featureSet.features[0]; var selSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,255]), 4.5)); graphic.setSymbol(selSymbol); map.graphics.add(graphic); } } dojo.addOnLoad(init);AMD:var map, countyQuery, countyQueryTask; require([ "esri/map", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/renderers/SimpleRenderer", "esri/graphic", "esri/Color", "esri/tasks/query", "esri/tasks/QueryTask", "dojo/domReady!" ], function(Map, SimpleFillSymbol, SimpleLineSymbol,SimpleRenderer, Graphic, Color, Query, QueryTask) { map = new Map("map", { basemap: "streets", center: [-80.94, 33.646], zoom: 8, slider: false }); }); function zoomTocounty(county){ var cntyName = document.getElementById("txtSearch").value; map.graphics.clear(); //To query county by name and pass to ZoomTocountyGeometry function countyQueryTask = new QueryTask("MYSERVICEHERE"); countyQuery = new Query(); countyQuery.returnGeometry = true; countyQuery.where = "NAME"+'='+"'"+cntyName+"'"; countyQueryTask.execute(countyQuery,ZoomTocountyGeometry) } function ZoomTocountyGeometry(featureSet){ if(featureSet.features.length > 0){ var graphic =featureSet.features[0]; var selSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,255]), 4.5)); graphic.setSymbol(selSymbol); map.graphics.add(graphic); var timeEvent = setTimeout(map.setExtent(featureSet.features[0].geometry.getExtent().expand(2.5)), 1); //Timing events } }
