I have added a FeatureLayer to my web map for online editing. I have also set an event listener to the "graphic-add" event.
I use the Editor widget and the TemplatePicker widget.
I first choose a template from the TemplatePicker, and then digitize a graph on the map.
The plan is to call a function to update the attribute information after the graph is added to the featurelayer.
myEditingFLayer.on("graphic-add", updateGrpAttribute); updateGrpAttribute : function(evt){ var gg = evt.graphic; gg.attributes["UserName"] = userName; gg.attributes["LASTUPDATE"] = updateTime; gg.attributes["CntyFips"] = CNTY_ID; gg.attributes["CAPTUREMETH"] = "Placed on Map"; myEditingFLayer.applyEdits(null, [gg], null, EditNew_Success, error); } |
But, this handler is not consistently fired. If I see the progress bar displays, the designated event handler will not be executed.
Please advise.
Mike
