I am trying to copy the attribute values from one table to another, inside a loop. I am looping through one table and inside that loop I want to copy the attribute values to another table. I have copied attribute values over before, but using JoinField, but I do not want to use that in this code, as I am already looping through records. I have seen different code attempting to do this, but so far nothing has worked for me. The code I'm working with is:import arcpy import os import string import subprocess arcpy.env.workspace = r"c:\Users\matt\Desktop\Ditch\Database\Centerline.mdb" assetFeatureClass = "[Assets]" assetrows = arcpy.UpdateCursor(assetFeatureClass,"[Processed] <> 'Y'","","","") # for each row in the result set for row in assetrows: print row.getValue("Ditch_ID") #create asset #Insert code to call out ArcObjects utility... centerline = "[Pipeline_Centerline]" #update asset record attributes from asset table rows = arcpy.UpdateCursor(centerline) for row in rows: row.Ditch_ID = assetFeatureClass.Ditch_ID rows.updateRow(row)I get an error that states: Runtime error Traceback (most recent call last): File "<string>", line 24, in <module> AttributeError: 'str' object has no attribute 'Ditch_ID'
and I assume what is causing this is the row.Ditch_ID = assetFeatureClass.Ditch_ID section. What I am trying to do in this section is to copy to the current record in the Centerline table the 'Ditch_ID' attribute value from the outer loop's record in the Assets table. Also, I have to do this for several attributes (both tables have the same schema) and need to either iterate over the code for each, or somehow copy several attributes at once.
