Hello all,
I am seeing an issue where ArcPy TableToTable is creating duplicate fields in the output dbf.
Here are the headers in the CSV I am adding: MNAM, MCON, MAD1, MAD2, MCST, MZIP, GISKKK
and yes there is data in columns.
Here is the code I am running
arcpy<SPAN class="punctuation token">.</SPAN>TableToTable_conversion<SPAN class="punctuation token">(</SPAN>putCSVHere<SPAN class="punctuation token">,</SPAN> path<SPAN class="punctuation token">,</SPAN> toDBF<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
"putCSVHere" is path to CSV which I want to convert that contains the above headers.
"path" is the path to the folder where I am putting the new dbf.
"toDBF" is the name of the dbf file to be created.
My output dbf ends up with the following fields (headers):OID, MNAM, MCON, MAD1, MAD2, MCST, MZIP, GISKKK, Extra Fields: GISKKK_X, GISKKK_Y
Data in these fields: 43.6666666667, -1
My question is, where do these extra fields "_X" and "_Y" come from and where does that data come from? It's not in the CSV anywhere
Thank you,
James
