Good Morning, I am developing a GIS Web app using JavaScript, now i have the possibility to edit points in the Map and click on a button to have the polygon.What i should do now is to ad two other button one for add stops and the other to solve road, and i should consider the polygon as a barrier so when i click on solve road the app should give me a road between the two stops and avoid the polygon already created Below the code of creating the polygon (Need help on the second part please):<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Foggy Buffer Zone</title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #mapu { padding:0; } #titlePane { width:200px; height:300px; } .claro .dijitTitlePaneTitle { background: #A4BDA7; font-weight:600; color:#33292B; } .dijitButtonNode { background-color: #A4BDA7 !important; border: 1px solid #646750 !important; color:#33292B !important; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> require(["dojo/dom", "dojo/dom-attr", "dojo/_base/array", "dojo/_base/Color", "dojo/parser", "esri/config", "esri/map", "esri/graphic", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/toolbars/draw", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane" ], function(dom, domAttr, array, Color, parser, esriConfig, Map, Graphic, GeometryService, BufferParameters, Draw, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol) { var map, geo, tb; parser.parse(); map = new Map("map", { basemap: "streets", center: [54.407, 24.462], zoom: 13, }); esriConfig.defaults.io.proxyUrl = "/proxy"; esriConfig.defaults.io.alwaysUseProxy = false; geo = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); map.on("load", initToolbar); /* ** Initialize the drawing toolbar */ function initToolbar(evtObj) { app.tb = new Draw(evtObj.map); app.tb.on("draw-end", drawPoint); } // Array where points are saved var list = new Array(); /* ** Draw point */ function drawPoint(evtObj) { // Get the click geometry var geometry = evtObj.geometry; // Point symbol var symbol = new SimpleMarkerSymbol( { "angle":0, "xoffset":0, "yoffset":12, "type":"esriPMS", "url":"http://www.iconexperience.com/_img/v_collection_png/512x512/shadow/cloud.png", "contentType":"image/png", "width":24, "height":24 } ); // Add point to the map var graphic = new Graphic(geometry, symbol); app.map.graphics.add(graphic); // Store the point geometry list.push(geometry) } /* ** Create the polygon around points */ function drawEndHandler(){ app.tb.deactivate(); geo.convexHull(list,function(result){ var symbol; switch(result.type){ case "point": symbol = new esri.symbol.SimpleMarkerSymbol(); break; case "polyline": symbol = new esri.symbol.SimpleLineSymbol(); break; case "polygon": symbol = new esri.symbol.SimpleFillSymbol(); break; } map.graphics.add(new esri.Graphic(result,symbol)); },function(error){ console.log("An error occured during convex hull calculation"); }); } app = { map: map, tb: tb, geo: geo, drawPolygon: drawEndHandler }; }); function drawClick(){ app.drawPolygon(); } /* ** Click on Point button */ function pointClick(){ app.tb.activate(esri.toolbars.Draw.POINT); app.map.hideZoomSlider(); } /* ** Click on Clear Graphics button */ function clearGraphicsClick(){ app.map.graphics.clear(); } </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="gutters:'false',design:'headline'" style="width: 100%; height: 100%;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Fog Warning System', closable:'false', open:'true'"> <p style="padding:5px 2px;color:#33292B;">Add foggy point and create the polygon.</p> <button data-dojo-type="dijit.form.Button" onclick="pointClick();">Report Fog</button> <button data-dojo-type="dijit.form.Button" type="button" onclick="clearGraphicsClick();">Clear</button> <button id="point" data-dojo-type="dijit.form.Button" type="button" onclick="drawClick();">Draw The Foggy Zone</button> </div> </div> </div> </div> </body> </html>
