Hi all,
I am using JQuery UI layout for my map template. I am now able with JQuery to toggle the inset map. What I am trying to achieve now is to start the map with the inset map off. IT works fine with either JQuery:
$('#draggable').hide();
or CSS:
display:none;
However, when using either one of these methods, the inset map gets messed up. (height/width/highligthbox) are all completely off.
You can access my map here.
The inset map id hidden at start as wished but it you click on the upper right corner of the map button to toggle it you will see that it gets messed up. I am not sure what is wrong with it. Any idea are welcome.
Alex
