TLDR; will getting our SSL certificate signed by a CA fix this problem? Our server security protocol has HTTP and HTTPS enforced.
I'm getting this error when trying to load a feature service from our AGS into a arcgis online map:
Unable to establish a secure connection to the layer. The layer, [layername], cannot be added to the map.
First, I'm a real beginner when it comes to AGS and http/https protocols. My knowledge is very limited, so bear with me. I am using AGS 10.6. I have been looking at this documentation:
https://enterprise.arcgis.com/en/server/latest/administer/windows/secure-arcgis-server-communication.htm
When I am on a machine that is not the server machine, I can login to our administrator but only using HTTP access (e.g. http://gisserver.domain.com:6080/arcgis/admin). I cannot access admin through HTTPS unless I am on the server machine. Our web adaptor is set up to not allow administrative access, so I know I cannot access AGS manager or admin through the web adaptor URL. When I try to reach our rest services through the web adaptor, I am able to use an HTTPS URL no problem.
Anyway, once in server admin, I go to security > config like it says and the protocol is set to allow HTTP and HTTPS access. SSL protocols include TLSv1.2 and the older ones. Now, I hop over to machines > [machine name] and it says our admin URL is https://gisserver.domain.com:6443/arcgis/admin. I check that our GIS server has the correct SSL certificate is assigned, which it is and it does not expire until 2028. We created this certificate last year and I assume it is self-signed, so it's not "trusted." When I go to sign into manager on the server machine I get the warning that the site is not secure. Considering our certificate has not been signed by a CA - if we get it signed by a CA, will this allow us to access our feature services on ArcGIS online? I need to get this to work so we can start using our server services in AGOL for use in Collector.
