I have problem when I try to use some st_geometry functions.
One of them is the st_buffer()
In the resource center there are a example for use it (st_buffer):
http://resources.arcgis.com/en/help/main/10.1/index.html#/ST_Buffer/006z0000003z000000/
But, look that happened when I try to run the query using sqlplus:
SQL> SELECT sa.id "Sensitive Areas", hs.name "Hazardous Sites"
2 FROM sensitive_areas sa, hazardous_sites hs
3 WHERE sde.st_overlaps (sa.zone, sde.st_buffer (hs.location, 0.01)) = 1;
ERROR at line 1:
ORA-28579: network error during callback from external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 325
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 1213
The curious is that others functions like st_relate works fine!
Anyone can help me?
ArcSDE 10.1 for Linux
Oracle 11g (11.2.0.3)
Thanks and regards.
Marcelo E. Peinado
Optimus GIS & IT Solutions
