Hi ,
I have 70 raster files and I want to make 3 new raster from each of the 70 raster. For that, I want to automate the process using python script and store the output new raster based on the raster file name plus value field. For example, My input raster is 01367620-r-r and 3 value fields are 9,11, and 13. So the output folder should be 01367620-r-r-9. 01367620-r-r-11, and 01367620-r-r-13. When I ran my code, I got the below error message. I think, I am doing mistake at "outname=os.path.join(outws,str(i), str(j))" in my code. I would appreciate your suggestion/input.
Error Message:
File "C:/Subhasis/Test/Neshanic_Python/Neshanic-test.py", line 23, in <module>
attExtract.save(outname)
RuntimeError: ERROR 000875: Output raster: C:\Subhasis\Test\Neshanic_Python\extract\01367620-r-r\9's workspace is an invalid output workspace.
I am providing my code below.
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python"
outws="C:/Subhasis/Test/Neshanic_Python/extract"
#checkout ArcGIS spatial analyst extension license
# set local variable
inraster = ["01367620-r-r"]
for i in inraster:
STI_list=[9,11,13]
for j in STI_list:
attExtract = ExtractByAttributes(str(i), "VALUE>=" + str(j))
Thanks!
