I need a line measurement to match my buffer distance. The code modifications should related to this article: Measuring distances and areas when your map uses the Mercator projection | ArcGIS Blog
Currently I have a buffer that uses a WKID of 4326 which appears to draw correctly with a measured buffer of 500 feet. The rest of the application uses a WKID 102100 which allows the application to display correctly, but the line tool is coming up with a measurement of about 150 feet more than the buffer. I have changed each 102100 one at a time even ones I did not think I should as I need this app to work in testing. Any idea where I am going wrong with my code so that my measurements work?
Here is my code:
/// <reference path="scriptaculous.js" />
/// <reference path="dragdrop.js" />
/// <reference path="effects.js" />
/// <reference path="rico.js" />
/// <reference path="ricoStyles.js" />
/// <reference path="ricoCommon.js" />
/// <reference path="ricoEffects.js" />
// Using Intellisense For The Above
// http: //msdn.microsoft.com/en-us/library/bb385682.aspx
////////// AUTHOR & APPLICATION INFORMATION ////////////////////////////////////////
// Author: Chris Sergent
// Date: May 1, 2012
// Application: SOA
// Address Points - Layer 0
// Bike Paths - Red Line - Layer 1
// Inhome Daycares - Dark Blue - Layer 2
// Daycare Facilities - Light Blue - Layer 3
// Playgrounds - Purple - Layer 4
// School Property - Green - Layer 5
// Macon Co. Tax Parcels - Layer 6
// Decatur Corporate Boundary - Layer 7
// DECLARE AND SET VARIABLES BEGIN
// SET UP DOJO BEGIN
Dojo Framework Require Begin
dojo.require("dojo.parser");
dojo.require("dojo.number");
Parsing dojo.number include four functions
- dojo.number.format() - formats numeric values
- dojo.number.parse() - converts a string to a number
- dojo.number.regexp() - returns a regular expression
- dojo.number.round() - rounds numbers
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dojo.fx");
dojo.require("dijit.dijit");
dojo.require("dijit.form.Button");
dojo.require("dijit.Toolbar");
dojo.require("dijit.TitlePane");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.Editor");
dojo.require("dijit.layout.TabContainer");
dojo.require("dojox.grid.DataGrid");
// Declare Rounding Corners With Rico
var roundCorners = Rico.Corner.round.bind(Rico.Corner);
Dojo Framework Require End
// REST API - Making Tools Available
// ESRI dojo objects
// allows you to work with the dynamic map service resource exposed by the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#
dojo.require("esri.layers.agsdynamic"); // dynamic map services generate images on the fly.
dojo.require("esri.layers.agstiled"); // cached map service.
// esri.Map class created a container and required DOM structure for adding
// -layers, graphics, info_window, and other navigation controls
dojo.require("esri.map");
dojo.require("esri.toolbars.navigation");
dojo.require("esri.toolbars.draw");
// ESRI dojo tasks
// esri.tasks.geometry class represents a geometry service exposed by the ArcGIS REST API.
// Operations include - project, simplify, buffer, and relationships
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/geometry.htm#
dojo.require("esri.tasks.geometry");
// Represents a geocode service resource exposed by the ArcGIS REST API.
// It is used to generate candidates for an address.
// It is also used to find an address for a given location.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/locator.htm#
dojo.require("esri.tasks.locator");
// ESRI dojo task for querying against the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/querytask.htm#
dojo.require("esri.tasks.query");
// ESRI dojo task for identifying against the ArcGIS REST API.
dojo.require("esri.tasks.identify");
// ESRI dojo graphics utility for displaying features in a single layer using the ArcGIS REST API.
// Reference:http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/featurelayer.htm#
dojo.require("esri.layers.FeatureLayer");
ESRI Dojo Objects End
// SET UP DOJO END
// DECLARE AND SET VARIABLES END
// MAP EXTENTS
Set the extent of one map service.
For multiple map services, see the section titled Setting the beginning extent
when using multiple services at-
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jshelp_start.htm
////WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING/////////
// WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING
// ENSURE YOU HAVE A GEOMETRY SERVICE CREATED AND RUNNING ON
// ESRI ArcGIS Server OR YOUR MAP MAY NOT DISPLAY
// NOTE: You do not necessarily need to reference the geometry service
// in your code.
// Extent and Spatial reference of our map service
//var startExtent = new esri.geometry.Extent({ "xmin": 778733.96207758, "ymin": 1133387.86320644, "xmax": 849794.792685476, "ymax": 1193607.08672764, "spatialReference": { "wkid": 102100} });
// This is the required projection to display in Decatur for imagery
var startExtent = new esri.geometry.Extent({ "xmin": -9907408.2369, "ymin": 4839236.5572, "xmax": -9897146.5658, "ymax": 4847826.1683, "spatialReference": { "wkid": 102100} });
// Sets the extent for the find address query
var addressExtent, newExtent;
// Map Services Begin
// Define Map Section
var gisUrl; // GIS Server Location
// Old Url - http://64.107.106.57/
gisUrl = "http://decgis01/";
var rasSvc; // Raster Service
rasSvc = "Public/Aerial_2012/MapServer";
var mapSvc; // Map Service
mapSvc = "Internal/SOA/MapServer";
var addrLocSvc; // Address Locator Service
addrLocSvc = "Public/WebAddressLocator/GeocodeServer";
var geomSvc; // Geometry Service
geomSvc = "Utilities/Geometry/GeometryServer";
var map, dynamicMapServiceLayer, imageDynamicMapServiceLayer;
dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + mapSvc);
dynamicMapServiceLayer.setOpacity(0.4);
//imageDynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + rasSvc);
imageDynamicMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#setImageFormat
//imageDynamicMapServiceLayer.setImageFormat("jpg");
// Navigation Tools
var navToolbar;
// Locator service to be used for find address
var locator;
locator = new esri.tasks.Locator(gisUrl + "arcgis/rest/services/" + addrLocSvc);
// SR required for Decatur
var spatialReference = new esri.SpatialReference({ wkid: 102100 });
locator.setOutSpatialReference(spatialReference);
// Geometry Service
var geometryService;
geometryService = new esri.tasks.GeometryService(gisUrl + "arcgis/rest/services/" + geomSvc);
// Map Services End
// ESRI Tasks Begin
// Define Macon County Tax Parcels as Layer to Query
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/intro_querytask.htm#
var queryTask = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/6");
// Creates a new query to be used against the current geometry
var queryParams = new esri.tasks.Query();
var circleSymbol = new esri.symbol.SimpleMarkerSymbol();
circleSymbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
circleSymbol.setColor(new dojo.Color([153, 0, 51, 0.75]));
// Declare coordinate for drawing point in find address
var x1, y1;
// Declare geometry for find address
var geom;
// Identify Task
var identifyHandle;
var identifyTask, identifyParams;
// Measure Polyline
var measureLine;
var lineLengthParams = new esri.tasks.LengthsParameters();
var measureLineGraphic;
// Measure Polygon
var measurePolygon;
var polygonLengthParams = new esri.tasks.AreasAndLengthsParameters();
var measurePolygonGraphic;
// Project Point
var pt = null;
var point;
var ptSymbol;
var ptGraphic;
var ptOutSR;
var pointHandle;
var inTown;
// ESRI Tasks End
// Query Layers Begin
// Layers to evaluate if they are in a safe zone based on a sex offender's potential address
var qryBikePaths = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/1")
var qryHomeDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/2");
var qryDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/3");
var qryParks = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/4");
var qrySchools = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/5");
var qryDecaturBoundary = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/7");
// Query Layers End
// Graphics Definition Begin
/* Define initial address point to be drawn for find address */
var firstGraphic;
/* Define queried point to be drawn for find address */
var graphicPt;
/* Defines the line drawn for the polygon of the parcel */
var selectParcel;
// Graphics Definition End
// PAGE INITIALIZATION
function init() {
// Initialize JavaScript Framework Controls
// Round Sidebar Corners
roundSidebarCorners();
// Add Sidebar
addSideBar();
// Add Sidebar Title
addSideBarTitle();
// Add Map Navigation Title
addMapNavigationTitle();
// Add Map Navigation Content
addMapNavigationContent();
// Add Map Tools Title
addMapToolsTitle();
// Add Map Tools Content
addMapToolsContent();
// Add Address Search Title
addAddressQueryTitle();
// Add Address Search Content
addAddressQueryContent();
$("sideBarTop").style.cursor = "hand"; // Sidebar Top - To Drag the Sidebar
$("sideBarTopFill").style.cursor = "hand"; // Sidebar Top Fill - To Drag the Sidebar
$("sideBarBottom").style.cursor = "hand"; // Sidebar Bottom - To Drag the Sidebar
$("sideBarBottomFill").style.cursor = "hand"; // Sidebar Bottom Fill - To Drag the Sidebar
$("dojoGrid").style.display = 'none';
$("btnClearGraphics").style.display = 'none';
// Add Footer Section
addFooterSection();
addFooter();
// Enable Sidebar Drag
EnableDrag();
// Set Browser to Full Size
maxBrowserWindow();
The proxy section is defined on the ESRI sample. I have included it as
part of the documentation reads that the measuring will not work.
I thought that might be important.
// Proxy Definition Begin
//identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
//If this null or not available the project and lengths operation will not work. Otherwise it will do a http post to the proxy.
esriConfig.defaults.io.proxyUrl = "proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = false;
// Proxy Definition End
// Programmatically define web services
// Add controls to the interface
esriConfig.defaults.map.sliderLabel = null;
// Note:
// The last layer added to the map is the top layer.
// Setting the opacity as shown below allows for hidden
// layers to become visible.
// LAYERS
/* Add a dynamic layer */
All map services use a unique reference to identify the map service
In ESRI ArcGIS Server, the unique reference is the URL of the published
map service
map = new esri.Map("mapSection", { extent: startExtent });
// Enable identify
dojo.connect(map, "onLoad", initFunctionality);
// The dynamic layer is added to the map
map.addLayer(imageDynamicMapServiceLayer);
map.addLayer(dynamicMapServiceLayer);
//alert(dynamicMapServiceLayer.layerInfos[5].name);
//alert((dynamicMapServiceLayer.visibleLayers.length) + 1);
// Add toolbar
navToolbar = new esri.toolbars.Navigation(map);
// Sets the navigation bar up to handle previous and next extent
dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
// Reference - http://forums.arcgis.com/threads/48318-Set-zoomToFullExtent-to-be-my-Initial-Extent
navToolbar.zoomToFullExtent = function () {
map.setExtent(startExtent);
// Add Polygon Tool
measurePolygon = new esri.toolbars.Draw(map);
dojo.connect(measurePolygon, "onDrawEnd", function (geometry) {
removePolygon();
deactivatePoint();
// This line of code is a guess
polygonLengthParams.polygons = [geometry];
polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_SQUARE_FEET;
polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_ACRES;
geometryService.simplify([geometry], function (simplifiedGeometries) {
polygonLengthParams.polygons = simplifiedGeometries;
geometryService.areasAndLengths(polygonLengthParams);
geometryService.lengths(polygonLengthParams);
measurePolygonGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleFillSymbol()));
// Add Line Tool
measureLine = new esri.toolbars.Draw(map);
dojo.connect(measureLine, "onDrawEnd", function (geometry) {
deactivatePoint();
removePolygon();
lineLengthParams.polylines = [geometry];
lineLengthParams.lengthUnit = esri.tasks.GeometryService.UNIT_FOOT;
lineLengthParams.geodisc = true;
geometryService.lengths(lineLengthParams);
measureLineGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleLineSymbol()));
// Diplay Polygon Area and Distance after measuring
dojo.connect(geometryService, "onAreasAndLengthsComplete", outputAreaAndLength);
// Display Line Distance after measuring
dojo.connect(geometryService, "onLengthsComplete", outputDistance);
// Make Address Locator Available
dojo.connect(locator, "onAddressToLocationsComplete", showResults);
// Connect the row click item to the dojo grid
dojo.connect(dojoGrid, "onRowClick", onRowClickHandler);
// Enable tab display for identify
dojo.connect(map.infoWindow, "onShow", function () {
dijit.byId("tabs").resize();
Map Tools Begin
// Add history reference for previous and next extent on map toolbar
function extentHistoryChangeHandler() {
$("btnPrevExtent").disabled = navToolbar.isFirstExtent();
$("btnNextExtent").disabled = navToolbar.isLastExtent();
Find Address Point Function Begins
function findAddress() {
if (Page_IsValid) {
// Clear the map
map.graphics.clear();
$("lblResponse").innerHTML = "";
$("lblAddressStatus").innerHTML = "";
var add = dojo.byId("txtAddress").value.split(",");
var address = {
SingleKey: add[0]
Locator begins searching for address matches when the method addressToLocations is called.
The event listener onAddressToLocationsComplete calls the function showResults()
onAddressToLocationsComplete fires when Locator.addressToLocation() has completed
locator.addressToLocations(address);
function showResults(candidates) {
var candidate;
var symbol = new esri.symbol.SimpleMarkerSymbol();
var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}");
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
symbol.setColor(new dojo.Color([255, 0, 0, 0.75]));
var points = new esri.geometry.Multipoint(map.spatialReference);
var incrementor = 0;
var validRecords = 0;
var xLoc, yLoc, singleAddress;
$("dojoGrid").style.display = 'inherit';
var items = [], obj = {}, loc;
dojo.forEach(candidates,
function (candidate) {
if (candidate.score > 50) {
obj = {};
obj['address'] = candidate.address;
obj['score'] = candidate.score;
loc = candidate.location;
obj['x'] = loc.x;
obj['y'] = loc.y;
obj['location'] = loc.x + ', ' + loc.y;
items.push(obj);
console.log(items);
// Create data object to be used in store
var data = {
items: items
// Create data store and bind to grid
store = new dojo.data.ItemFileReadStore({ data: data });
var grid = new dojox.grid.DataGrid;
grid = dijit.byId('dojoGrid');
grid.setStore(store);
// Evaluate number of addresses returned
// if there is only one address, set the height of the grid to 0
if (items.length == 1) {
$("dojoGrid").style.height = 0
else {
// if there is more than one address set the height 50x the number of items addresses returned
$("dojoGrid").style.height = 50 * items.length;
// Evaluate if any candidates exist
if (candidates.length == 0) {
$("lblAddressStatus").innerHTML = "The Address you entered is not recognized. Make sure you entered it correctly.";
$("lblAddressStatus").className = "warningMessage";
$("lblResponse").innerHTML = " Your address should be like the example:" +
"<br> 111 E MAIN ST " +
"<br> And the format should be:" +
"<br> Street Address";
$("lblResponse").className = "warningMessage";
$("lblBikePath").innerHTML = "";
$("lblHomeDayCare").innerHTML = "";
$("lblDayCare").innerHTML = "";
$("lblParks").innerHTML = "";
$("lblSchools").innerHTML = "";
$("lblCityLimits").innerHTML = "";
navToolbar.zoomToFullExtent();
// exit code
return;
else {
// Check all candidates for a matching score greater than 50
for (incrementor; incrementor < candidates.length; incrementor++) {
candidate = candidates[incrementor];
var attributes = { address: candidates[incrementor].address, score: candidates[incrementor].score };
var graphic = new esri.Graphic(candidates[incrementor].location, symbol, attributes, infoTemplate);
map.graphics.add(graphic);
map.graphics.add(new esri.Graphic(candidate.location, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 8)));
points.addPoint(candidate.location);
validRecords = incrementor + 1;
xLoc = candidates[incrementor].location.x;
yLoc = candidates[incrementor].location.y;
singleAddress = candidates[incrementor].address;
if (validRecords > 1) {
$("lblAddressStatus").innerHTML = "Success!";
$("lblAddressStatus").className = "normalMessage";
map.setExtent(points.getExtent().expand(3));
$("btnClearGraphics").style.display = 'inherit';
else if (validRecords == 0) {
else if (validRecords == 1) {
// Coordinates of single address returned
$("lblAddressStatus").innerHTML = "The Address " + singleAddress + " was found.";
map.setExtent(points.getExtent());
x1 = xLoc;
y1 = yLoc;
geom = new esri.geometry.Point(x1, y1, new esri.SpatialReference({ wkid: 343 }));
graphicPt = new esri.Graphic(geom, symbol);
// Add Point
map.graphics.add(graphicPt);
// Initialize Query
var qry = new esri.tasks.Query();
qry.returnGeometry = true;
qry.ourSpatialReference = { "wkid": 102100 };
qry.geometry = geom;
// Check if point is in city limits
qry.spatialRelationship = esri.tasks.Query.SPATIAL_INTERSECTS;
qryDecaturBoundary.execute(qry, qryDecaturBoundary_complete);
Display Grid Cell That Was Clicked
function onRowClickHandler(evt) {
// Set X and Y Coordinates
x1 = dojoGrid.getItem(evt.rowIndex).x;
y1 = dojoGrid.getItem(evt.rowIndex).y;
// Declare geometry and assign coordinates
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#PointConst1
// Required for Decatur
geom = new esri.geometry.Point(x1[0], y1[0], new esri.SpatialReference({ wkid: 102100 }));
graphicPt = new esri.Graphic(geom, circleSymbol);
// Add Point
// Initialize Query
// Custom Buffer Sample
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/util_buffergraphic.html#
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/exp_cors_buffer.html
function doBuffer(geometry) {
// Set up buffer parameters
var params = new esri.tasks.BufferParameters();
params.distances = [500];
params.bufferSpatialReference = new esri.SpatialReference({ wkid: 3435 });
params.outSpatialReference = map.spatialReference;
params.unit = esri.tasks.GeometryService.UNIT_FOOT;
geometryService.simplify([geometry], function (geometries) {
params.geometries = geometries;
geometryService.buffer(params, showBuffer);
function showBuffer(bufferedGeometries) {
var symbol = new esri.symbol.SimpleFillSymbol(
esri.symbol.SimpleFillSymbol.STYLE_SOLID,
esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([255, 0, 0, 0.65]), 2
new dojo.Color([255, 0, 0, 0.35])
var graphic;
dojo.forEach(bufferedGeometries, function (geometry) {
graphic = new esri.Graphic(geometry, symbol, { buffer: true });
// Add point
// Add polygon
map.graphics.add(firstGraphic);
// Add Buffer
map.setExtent(bufferedGeometries[0].getExtent().expand(2));
// evaluate if buffered geometries intersect with safe zones
queryParams.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
queryParams.returnGeometry = true;
queryParams.geometry = graphic.geometry;
// Evaluate if buffer intersects with bikepaths
qryBikePaths.execute(queryParams, qryBikePaths_complete);
// Evaluate if buffer intersects with a daycare
qryDayCare.execute(queryParams, qryDayCare_complete);
// Evaluate if buffer intersects with playground equipment
qryParks.execute(queryParams, qryParks_complete);
// Evaluate if buffer intersects with a Home Daycare
qryHomeDayCare.execute(queryParams, qryHomeDayCare_complete);
// Evaluate if buffer intersects with a school
qrySchools.execute(queryParams, qrySchools_complete);
// Evaluate if address is in City Limits
function qryDecaturBoundary_complete(featureSets) {
if (featureSets.features.length > 0) {
// Initialize Query
var query = new esri.tasks.Query();
query.returnGeometry = true;
// This SR is requirer to draw the parcel polygon
query.outSpatialReference = { "wkid": 102100 };
query.geometry = geom;
// Checks where point intersects with parcel
query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
queryTask.execute(query);
// Declare the graphic for the polygon
firstGraphic = null;
selectParcel = null;
// +++++Listen for QueryTask onComplete event+++++
dojo.connect(queryTask, "onComplete", function (graphics) {
firstGraphic = graphics.features[0];
selectParcel = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([98, 194, 204]), 3), new dojo.Color([255, 0, 0, 0]));
firstGraphic.setSymbol(selectParcel);
// Add Polygon Graphic On parcel as Selection
geometry = graphics.features[0].geometry;
// Buffer polygon
doBuffer(geometry);
else {
$("lblResponse").innerHTML = "It's outside the city.";
return inTown;
// Evaluate Safe Zones
function qryBikePaths_complete(featureSet) {
if (featureSet.features.length > 0) {
$("lblBikePath").innerHTML = "Caution, Bikepath";
$("lblBikePath").className = "cautionMessage";
else {
$("lblBikePath").innerHTML = "Bikepath Safe";
$("lblBikePath").className = "successMessage";
function qryHomeDayCare_complete(featureSet) {
$("lblHomeDayCare").innerHTML = "Home Daycare Unsafe";
$("lblHomeDayCare").className = "warningMessage";
else {
$("lblHomeDayCare").innerHTML = "Home Daycare Safe";
$("lblHomeDayCare").className = "successMessage";
function qryDayCare_complete(featureSet) {
$("lblDayCare").innerHTML = "Daycare Unsafe";
$("lblDayCare").className = "warningMessage";
else {
$("lblDayCare").innerHTML = "Daycare Safe";
$("lblDayCare").className = "successMessage";
function qryParks_complete(featureSet) {
$("lblParks").innerHTML = "Parks Unsafe";
$("lblParks").className = "warningMessage";
else {
$("lblParks").innerHTML = "Parks Safe";
$("lblParks").className = "successMessage";
function qrySchools_complete(featureSet) {
$("lblSchools").innerHTML = "Schools Unsafe";
$("lblSchools").className = "warningMessage";
else {
$("lblSchools").innerHTML = "Schools Safe";
$("lblSchools").className = "successMessage";
function clearResults() {
$("txtAddress").value = "111 MAIN ST";
function initFunctionality(map) {
identifyTask = new esri.tasks.IdentifyTask(gisUrl + "arcgis/rest/services/" + mapSvc);
identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0, 1, 2, 3, 4, 5, 6];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
map.infoWindow.resize(415, 200);
map.infoWindow.setContent(dijit.byId("tabs").domNode);
map.infoWindow.setTitle("Identify Results");
function doIdentify(evt) {
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams, function (idResults) { addToMap(idResults, evt); });
function addToMap(idResults, evt) {
addressResults = { displayFieldName: null, features: [] }; // 0
inHomeDayCareResults = { displayFieldName: null, features: [] }; //2
dayCareFacilitiesResults = { displayFieldName: null, features: [] }; //3
playgroundResults = { displayFieldName: null, features: [] }; //4
schoolPropertyResults = { displayFieldName: null, features: [] }; //5
maconTaxParcelResults = { displayFieldName: null, features: [] }; // 6
// evaluate for layers 0,1, 3, 4, 5, and 6
for (var i = 0, il = idResults.length; i < il; i++) {
var idResult = idResults;
if (idResult.layerId === 0) {
if (!addressResults.displayFieldName) { addressResults.displayFieldName = idResult.displayFieldName };
addressResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(addressResults, "addressResults"));
i = idResults.length + 1;
else if (idResult.layerId === 2) {
if (!inHomeDayCareResults.displayFieldName) { inHomeDayCareResults.displayFieldName = idResult.displayFieldName };
inHomeDayCareResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(inHomeDayCareResults, "inHomeDayCareResults"));
else if (idResult.layerId === 3) {
if (!dayCareFacilitiesResults.displayFieldName) { dayCareFacilitiesResults.displayFieldName = idResult.displayFieldName };
dayCareFacilitiesResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(dayCareFacilitiesResults, "dayCareFacilitiesResults"));
else if (idResult.layerId === 4) {
if (!playgroundResults.displayFieldName) { playgroundResults.displayFieldName = idResult.displayFieldName };
playgroundResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(playgroundResults, "playgroundResults"));
else if (idResult.layerId === 5) {
if (!schoolPropertyResults.displayFieldName) { schoolPropertyResults.displayFieldName = idResult.displayFieldName };
schoolPropertyResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(schoolPropertyResults, "schoolPropertyResults"));
else if (idResult.layerId === 6) {
if (!maconTaxParcelResults.displayFieldName) { maconTaxParcelResults.displayFieldName = idResult.displayFieldName };
maconTaxParcelResults.features.push(idResult.feature);
dijit.byId("safeZoneTab").setContent(layerTabContent(maconTaxParcelResults, "maconTaxParcelResults"));
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function layerTabContent(layerResults, layerName) {
var content = "";
switch (layerName) {
case "addressResults":
content = "<i>Total features returned: " + layerResults.features.length + "</i>";
content += "<table border='1'><tr><th>Address</th><th>PIN</th></tr>";
for (var i = 0, il = layerResults.features.length; i < il; i++) {
content += "<tr><td>" + layerResults.features.attributes['ADDRESS'] + " </td>";
content += "<td>" + layerResults.features.attributes['PIN_NUM'] + "</td>";
content += "</tr></table>";
break;
case "inHomeDayCareResults":
content += "<table border='1'><tr><th>Description</th><th>Address</th></tr>";
content += "<tr><td>" + layerResults.features.attributes['USAGE_DESC'] + " </td>";
content += "<td>" + layerResults.features.attributes['ADDRESS'] + "</td>";
break;
case "dayCareFacilitiesResults":
content += "<table border='1'><tr><th>Description</th><th>Name</th></tr>";
content += "<tr><td>Daycare Facilities</td>";
content += "<td>" + layerResults.features.attributes['SCHOOL_NAM'] + "</td>";
break;
case "playgroundResults":
content += "<tr><td>Playgrounds</td>";
content += "<td>" + layerResults.features.attributes['PARKNAME'] + " </td>";
break;
case "schoolPropertyResults":
content += "<tr><td>School Property</td>";
break;
case "maconTaxParcelResults":
content += "<table border='1'><tr><th>Name</th><th>Address</th></tr>";
content += "<tr><td>" + layerResults.features.attributes['PRIMARYNAME'] + " </td>";
content += "<td>" + layerResults.features.attributes['SITEADDRESS'] + " </td>";
content += "</tr></table";
break;
return content;
function runIdentify() {
measureLine.deactivate();
removePolygon();
removePolyline();
measurePolygon.deactivate();
identifyHandle = dojo.connect(map, "onClick", doIdentify);
identifyHandle;
function outputDistance(result) {
dojo.byId("lblDistance").innerHTML = " " + dojo.number.format(result.lengths[0]) + " feet";
function outputAreaAndLength(result) {
console.log(dojo.toJson(result));
dojo.byId("lblDistance").innerHTML = " " + dojo.number.format(result.areas[0]) + " sq. feet";
function removePolyline() {
// Remove line graphics
map.graphics.remove(measureLineGraphic);
// Deactivate measure line
// Remove point
map.graphics.remove(ptGraphic);
// Deactivate pointhttp://maps.decaturil.gov/ArcGIS/rest/services/InternalMapSampleServiceTest/MapServer/2 or the current URL
dojo.disconnect(pointHandle);
function removeMeasureTools() {
// Remove point
// Deactivate point
// Remove polygon
map.graphics.remove(measurePolygonGraphic);
// Deactivate polygon
// Deactivates Navtoolbar and Identify
function deactivateNavToolbar() {
// Deactivate Toolbar
navToolbar.deactivate();
// Deactivate Identify
dojo.disconnect(identifyHandle);
// Deactivates Identify
function deactivateIdentify() {
// Disables identify
function projectPoint() {
// Remove the line graphics
// Remove polygon graphics
// Deactivate the nav toolbar
// Deactivate identify
deactivateIdentify();
// Wire up the point handle to run the projectToWebMercator
pointHandle = dojo.connect(map, "onClick", projectToWebMercator);
pointHandle;
function projectToWebMercator(evt) {
point = evt.mapPoint;
ptSymbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
ptGraphic = new esri.Graphic(point, ptSymbol);
ptOutSR = new esri.SpatialReference({ wkid: 102100 });
map.graphics.add(ptGraphic);
geometryService.project([point], ptOutSR, function (projectedPoints) {
point = projectedPoints[0];
dojo.byId("lblDistance").innerHTML = " x:" + dojo.number.format(point.x) + ", y:" + dojo.number.format(point.y);
// Disconnect point handle
function clearPointAndPolygon() {
removePoint();
removePolygon();
function clearPointAndLine() {
removePoint();
removePolyline();
function removePoint() {
function removePolygon() {
function deactivatePoint() {
function printMap() {
alert("Print Map");
function getHelp() {
alert("Help Me");
Map Tools End
// Rico Functions
function roundSidebarCorners() {
roundCorners('sideBarTop',
corners: "top",
color: "#E1EBFB"
roundCorners('sideBarBottom',
corners: "bottom",
color: "#E1EBFB"
// Dojo Function
// Add Sidebar
function addSideBar() {
var sideBarConfig = new dijit.layout.BorderContainer({
$("sideBar")
function addSideBarTitle() {
var sideBarTitleConfig = new dijit.TitlePane({
title: "SOA Tools"
$("sideBarTitle")
// Add Map Navigation title
function addMapNavigationTitle() {
var mapNavigationTitleConfig = new dijit.TitlePane({
title: "Navigation", open: true
$("mapNavigationTitle")
function addMapNavigationContent() {
var mapNavigationContentConfig = new dijit.layout.ContentPane({
$("mapNavigationContent")
function addMapToolsTitle() {
var mapToolsTitleConfig = new dijit.TitlePane({
title: "Map Tools", open: false
$("mapToolsTitle")
function addMapToolsContent() {
var mapToolsContentConfig = new dijit.layout.ContentPane({
$("mapToolsContent")
// Add Address Query Title
function addAddressQueryTitle() {
var addressQueryTitleConfig = new dijit.TitlePane({
title: "Address Search", open: true
$("queryAddressTitle")
// Add Query Address Content
function addAddressQueryContent() {
var addressQueryContentConfig = new dijit.layout.ContentPane({
$("queryAddress")
function addFooterSection() {
var footerSection = new dijit.TitlePane({
title: "Ask For Assistance", open: false
$("footerTitle")
// Add Footer
function addFooter() {
var pageFooter = new dijit.layout.ContentPane({
$("footer")
// Scriptaculous Functions
function EnableDrag() {
new Draggable($("sideBar"));
//Maximize Browser Window Begin
// Reference - http://www.javascriptfreecode.com/53.htm
function maxBrowserWindow() {
top.window.moveTo(0, 0);
if (document.all) {
top.window.resizeTo(screen.availWidth, screen.availHeight);
else if (document.layers || document.getElementById) {
if (top.window.outerHeight < screen.availHeight || top.window.outerWidth < screen.availWidth) {
top.window.outerHeight = screen.availHeight;
top.window.outerWidth = screen.availWidth;
// Maximize Browser Window End
// Initialize Page
