I am creating a csv file via the SearchCursor. This Works great....although I am not getting the field names in there. I went about this 2 ways. I have tried a ton of forums but just cant seem to get the right syntax to create this ONLY once and when I bring it into Excel it has a header for each field.
Any thoughts?
I add the headers IN the "for row in cursor"
This adds them BUT it creates a set of headers for each record imported
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN>var_region_1 <SPAN class="punctuation token">,</SPAN>var_county_1<SPAN class="punctuation token">,</SPAN>var_ramp_1<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> where_clause<SPAN class="operator token">=</SPAN>expression<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
zval <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{0},{1},{2}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
headers <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'region_1'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'county_1'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'ramp_1'</SPAN><SPAN class="punctuation token">]</SPAN>
outFile<SPAN class="punctuation token">.</SPAN>write<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'\t'</SPAN><SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>headers<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">'\n'</SPAN><SPAN class="punctuation token">)</SPAN>
outFile<SPAN class="punctuation token">.</SPAN>write<SPAN class="punctuation token">(</SPAN>zval <SPAN class="operator token">+</SPAN> <SPAN class="string token">"%s\n"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Add headers BEFORE the "for row in cursor"
This adds them but when I bring into excel they are all crammed into the first box, not spread out for each field.
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
