When the user clicks a graphic, I want to create a temporary graphic (with the same geometry) to edit in SketchViewModel.
Basically this code, using ArcGIS JavaScript API 4.10:
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>sketchViewModel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SketchViewModel</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
layer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>tempLayer<SPAN class="punctuation token">,</SPAN>
view<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">,</SPAN>
updateOnGraphicClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>hitTestResult<SPAN class="punctuation token">:</SPAN> esri<SPAN class="punctuation token">.</SPAN>HitTestResult<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> hitGraphics <SPAN class="operator token">=</SPAN> hitTestResult<SPAN class="punctuation token">.</SPAN>results
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">filter</SPAN><SPAN class="punctuation token">(</SPAN>x <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> x<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>layer <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>graphicsLayer<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN>x <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> x<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>hitGraphics<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> tempGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> hitGraphics<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clone</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>tempLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>tempGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">update</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>tempGraphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
tool<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"transform"</SPAN><SPAN class="punctuation token">,</SPAN>
enableRotation<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
enableScaling<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
toggleToolOnClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>However, ArcGIS gives me the following error message:
"Parameter 'graphics' contains one or more graphics missing from the supplied GraphicsLayer."
What am I doing wrong? I'm guessing this is a threading/timing issue that happens because hitTest() is asynchronous, but I'm not sure how to work around it.
