I'm trying to turn on the highlight settings for layers that are clicked on and came across the highlightOptions setting within the MapView but I can't get it to work.
I added the following but nothing happens:
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> webmap<SPAN class="punctuation token">,</SPAN>
rotation<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">340</SPAN><SPAN class="punctuation token">,</SPAN>
highlightOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
haloOpacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">,</SPAN>
fillOpacity<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.2</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>What am I missing?
Scott
