I would like to identify the Kth order neighbors of an edge on a network, specifically the neighbors of a large set of streets. For example, I have a street that I'm interested in looking at, call this the focal street. For each focal street I want to find the streets that share an intersection, these are the first order neighbors. Then for each of those streets that share an intersection with the focal street I would like to find their neighbors (these would be the second order neighbors), and so on...Calculating the first order neighbors using ArcGIS' geoprocessing library (arcpy) took 6+ hours, second order neighbors has been running for 20+ hours. Needless to say I want to find a more efficient solution. I have created a python dictionary which is keyed on each street and contains the connected streets as values. For example:st2neighs = {street1: [street2, street3, street5], street2: [street1, street4], ...}. street 1 is connected to street 2, 3, 5; street 2 is connected to street 1 and 4; etc.. There are around 12000 streets in the study area most have fewer than 7 connected streets. I have tried to do this using python-only and have not succeeded (see here). SelectLayerByLocation_management seems insanely slow. My read of the forums has turned up little, one person suggests recursively buffering each street and then making an in-memory layer but it is unclear to me how this would add efficiency (it increases the required number SelectLayerByLocation calls, doesn't it?).A pickled version of the st2neighs used in the code below is here. The intended behavior is: For each street in the city (focal street):[INDENT]For each of the focal streets neighbors (focal street neighbor):[INDENT]Select the neighbors of the focal street neighbor using SelectLayerByLocation [/INDENT][/INDENT]Any thoughts on why the code below is taking so long to run? Did I make a mistake? By my estimates the code involves ~ 72000 calls to SelectLayerByLocation. The code has been running about 20 hours so that's about 1 second per SelectLayerByLocation (and it isn't done yet). Is this normal? Can the efficiency be improved somehow? Thanks for your help and code follows...##This Script Creates and pickles a dictionary of street connectivity
##IMPORT LIBRARIES
import cPickle as pickle
import arcpy
##LOAD DATA
#Set workspace to geodatabase
arcpy.env.workspace = "aGDB.gdb/aLayer"
st_file = open("st2neighs.pkl", "rb")
#st2neighs contains first order neighbors
st2neighs = pickle.load(st_file)
#Make layers
arcpy.MakeFeatureLayer_management("SSOStreetsMerged", "strLyr")
#Second order neighbors
for street in st2neighs:
for astreet in st2neighs[street]:
arcpy.SelectLayerByAttribute_management("strLyr", "NEW_SELECTION", "\"ID\" = " + str(astreet))
arcpy.SelectLayerByLocation_management("strLyr", "INTERSECT", "strLyr", "", "NEW_SELECTION")
neighs = arcpy.SearchCursor("strLyr", "", "", "", "")
for aneigh in neighs:
neigh = int(aneigh.getValue("ID"))
if neigh != street:
if neigh not in st2neighs[street]:
st2neighs[street].append(neigh)
pfile = open("st2neighs2.pkl", "wb")
pickle.dump(st2neighs, pfile)
pfile.close()
