Hi
I have a GraphicsLayer, and want the user to click on shapes in that layer to display information that I only hold locally. I am using the Map.infoWindow object for the popup so that it is identical to the ESRI standard infoWindow.
When the size of the map is bigger than the "mobileBreakPoint" URL parameter (default 600px) then Map.infoWIndow is an instance of Popup, and when it's below that threshold then it's a PopupMobile, but the documentation says they share a common API and should therefore be interchangeable as far as my code is concerned.
However the Popup displays my HTML content flawlessly, but the PopupMobile opens with no content, it's empty. This is true even if the content is a simple string, ie "test".
Here's my code:
myLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
evt<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stopPropagation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> iw <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">;</SPAN>
iw<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
iw<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>myHTMLContent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
iw<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I've attached a couple of images, infoWindow01 shows Popup working with "test" for content, and infoWIndow02 shows PopupMobile not working, all I did was shrink the map window between snapshots.
Many thanks!
