I had this code running just fine, but now all of the rows that are inserted are Zero length and I'm stumped. This grabs From/To XY's and then builds a line from them. The other stuff in here tests for duplicates. I print out the XY's so I know that I have them. What's going on?!import arcpy
import sys
arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(32043)
try:
#import pprint
pgTbl = r'Database Connections\Connection to myDb'
output = r'\\xyz\xyz.gdb\Connections'
arcpy.DeleteFeatures_management(output)
print 'empty fc'
xys = []
with arcpy.da.SearchCursor(pgTbl, ['occ_num', 'cc_x_coord', 'cc_y_coord', 'x_coord', 'y_coord']) as c:
for r in c:
if r[0] and r[1]:
xys.append([r[0], r[1], r[2],r[3], r[4]])
del r, c
for i in xys:
#print i
if i[1] == i[3]:
if i[2] == i[4]:
xys.remove(i)
xys.sort()
for i in xys:
print i
for j in xys:
myList = []
myList.append(arcpy.Point(j[1], j[2]))
myList.append(arcpy.Point(j[3], j[4]))
array = arcpy.Array(myList)
polyline = arcpy.Polyline(array)
cursor = arcpy.da.InsertCursor(output, ("SHAPE@"))
cursor.insertRow((polyline,))
print 'inserted row'
del cursor, polyline
arcpy.Compact_management(r'\\xyz\xyz.gdb')
print 'compact'
except:
sys.exit()
finally:
import gc
gc.collect()
