Hi. Working with 4.10 api, I'd like to have a widget render in a popup. The popup would be an accordion like interactive interface. I have modified the popup style so it is large enough to contain the widget, but not sure the best way to create the widget inside the popup. Typically, you would add the widget to an app like below, but that div does not exist in the interface. Rather it would need to be created dynamically when the popup content is created.
<SPAN class="keyword token">var</SPAN> widget <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">myWidget</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"myWidgetDiv"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I know the popup content can be generated via a function. Seems that would be the way to handle this but having trouble wrapping my head around how exactly to go about it.
Any suggestions would be appreciated.
