I am trying to combine two scripts that I found on esri.com into one script - 1. identify two mapservice layers - "click" event identify task and popups - works well.2. edit a featureservice layer using - "layers-add-result" event and template picker - doesn't work.I would like to have the application to do the following - 1. when clicked on a feature from mapservice (polygons) the identify poppup window should display results 2. but if clicked on point feature service only the edit functionality should work. points and polygons do overlap.I am just getting my feet wet in esri javascript api. Any help is really appreciated.Thank you!BC
var precURL = "http://server/arcgis/rest/services/Polys/MapServer"
var addressURL = "http://server/arcgis/rest/services/Points/FeatureServer/0";
var visibleLayers = [0,1];
var mapTitle = "Address pts";
var map, mapLayer, featureLayer, fLayer;
Define the map application script using "require" to load the necessary modules.
See documentation here: "http://dojotoolkit.org/documentation/tutorials/1.8/modules/" for more information.
This includes standard ESRI modules as well as custom modules included with the application.
require([
"esri/map",
"esri/dijit/HomeButton",
"esri/geometry/Extent",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/dijit/Scalebar",
"esri/dijit/PopupTemplate",
"esri/dijit/Popup",
"esri/dijit/Geocoder",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"esri/tasks/IdentifyResult",
"esri/geometry/screenUtils",
"dojo/_base/array",
"dojo/parser",
"modules/customBasemaps",
"modules/clickLegend",
"dojo/dom",
"dojo/dom-construct",
"esri/config",
"esri/toolbars/edit",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/symbols/SimpleMarkerSymbol",
"esri/dijit/editing/Editor-all",
"esri/dijit/editing/TemplatePicker",
"esri/config",
"dojo/i18n!esri/nls/jsapi",
"dojo/keys",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
function(
Map,
HomeButton,
Extent,
ArcGISDynamicMapServiceLayer,
FeatureLayer,
Scalebar,
PopupTemplate,
Popup,
Geocoder,
IdentifyTask,
IdentifyParameters,
IdentifyResult,
screenUtils,
arrayUtils,
parser,
CustomBasemaps,
ClickLegend,
dom,
domConstruct,
esriConfig,
Edit,
ArcGISTiledMapServiceLayer,
SimpleMarkerSymbol,
//SimpleLineSymbol,
Editor,
TemplatePicker,
jsapiBundle,
keys
parser.parse();
// Set the document (webpage) title.
document.title = mapTitle;
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy";
// Create a dynamic map service layer object using the global mapLayer variable.
mapLayer = new ArcGISDynamicMapServiceLayer(precURL);
// Address layer
featureLayer = new FeatureLayer(addressURL,{
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ['*']
//labels
var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
//change in prod
esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
// Set a variable to the extent with the desired spatial reference.
// Create the map variable with basemap, extent, and minScale.
map = new esri.Map("map", {
basemap: "streets",
center: [-70.34, 30.0],
zoom: 10
//Legend
var legend = new ClickLegend();
// Send the service url to the "setLayers" method of ClickLegend to create the legend.
legend.setLayers([precURL]);
// Use the custom basemap module to create create a basemap gallery with the desired basemap layers.
// The layers can be changed by editing the code in the "customBasemaps.js" module.
var basemapGallery = new CustomBasemaps({
showArcGISBasemaps: false,
map: map
}, "basemapMenu");
basemapGallery.startup();
//esriConfig.defaults.io.proxyUrl = "/proxy";
// Set functions to occur once the map has loaded.
map.on("load", function(){
// Using ESRI module, add a scale bar to the map. CSS style can be modified in layout.css.
var scalebar = new Scalebar({
map:map,
scalebarUnit:"english"
//Home button
var home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
// Using ESRI module, add a new geocoder search widget. CSS style can be modified in layout.css.
var search = new Geocoder({
map:map
}, "search");
search.startup();
// Set legal disclaimer language.
//alert("This GIS data product to be used for reference purposes only and is not to be construed as a legal document.");
var layerDefinitions = [];
layerDefinitions[0] = "COUNTY_ID = 1";
layerDefinitions[1] = "COUNTY_ID = 1";
mapLayer.setLayerDefinitions(layerDefinitions);
// Add the layer to the map.
map.addLayers([mapLayer,labels,featureLayer]);
// Set the visible layers using the visibleLayers variable.
mapLayer.setVisibleLayers(visibleLayers);
// Set identifyTask to run when the map is clicked.
map.on("click", function(evt){
// This code creates the identify functionality when a feature on the map is clicked.
//First create the identifyTask and identifyParameters variables. Then set the identifyParameters properties.
var identifyTask = new IdentifyTask(precURL);
var identifyParams = new IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
identifyParams.width = map.width;
identifyParams.height = map.height;
// Create a variable to hold the clicked point on the map.
var clickPnt = evt.mapPoint;
identifyParams.geometry = clickPnt;
identifyParams.mapExtent = map.extent;
identifyParams.layerIds = mapLayer.visibleLayers;
//identifyParams.layerIds = [0,1];
// Execute the identifyTask, which will return an array of popup templates to be stored in the "deferred" variable.
var deferred = identifyTask.execute(identifyParams);
deferred.addCallback(function(response) {
// The idenitifyTask returns an array of identify result objects
// This callback function is used to change it to an array of features each with
// a popup template based on the attribute fields for each feature.
return dojo.map(response, function(result) {
var feature = result.feature;
var fieldInfo = [];
for (var key in feature.attributes){
if (feature.attributes.hasOwnProperty(key)){
var info = {fieldName:"", visible:true};
info.fieldName = key;
fieldInfo.push(info);
feature.setInfoTemplate(new PopupTemplate({
title: result.layerName,
fieldInfos: fieldInfo
return feature;
// InfoWindow expects an array of features from each deferred
// object that you pass. If the response from the task execution
// above is not an array of features, then you need to add a callback
// like the one above to post-process the response and return an
// array of features.
// Set the infoWindow features to the array stored in the "deferred" variable.
map.infoWindow.setFeatures([ deferred ]);
// Set the anchor point for the infoWindow to the clicked point.
map.infoWindow.show(clickPnt);
//editor
map.on("layers-add-result", initEditor);
function initEditor(evt) {
var templateLayers = arrayUtils.map(evt.layers, function(result){
return result.layer;
var templatePicker = new TemplatePicker({
featureLayers: templateLayers,
grouping: true,
rows: "auto",
columns: 1
}, "templateDiv");
templatePicker.startup();
var layers = arrayUtils.map(evt.layers, function(result) {
//alert(result.layer.name);
return { featureLayer: result.layer };
var settings = {
map: map,
templatePicker: templatePicker,
//geometryService:geometryService,
layerInfos: layers
var params = {settings: settings};
var myEditor = new Editor(params,"editorDiv");
//define snapping options
myEditor.startup();
