Hi everyone,
We develop an android app that uses Portal for named user licence. When I want to listen portal load event. addDoneLoading listener is not called. Here is my code.
public class MainActivity extends AppCompatActivity {
private MapView mMapView;
private ProgressDialog pd;
Portal portal;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
String theURL = "http://********.ibb.gov.tr";
//request that the Named User logs in with their credentials
portal = new Portal(theURL, true);
portal.setCredential(Utils.getUserCredentialsPortal());
portal.addDoneLoadingListener(new Runnable() {
@Override
public void run() {
LoadStatus ls = portal.getLoadStatus();
switch (ls) {
case LOADING:
Toast.makeText(MainActivity.this, "Load Status 5 !!! " + portal.getLoadStatus().name(), Toast.LENGTH_SHORT).show();
break;
case LOADED:
LicenseInfo licenseInfo = portal.getPortalInfo().getLicenseInfo();
ArcGISRuntimeEnvironment.setLicense(licenseInfo);
break;
case NOT_LOADED:
portal.retryLoadAsync();
Toast.makeText(MainActivity.this, "Load Status 7!!! " + portal.getLoadStatus().name(), Toast.LENGTH_SHORT).show();
pd.dismiss();
break;
case FAILED_TO_LOAD:
//portal.retryLoadAsync();
Toast.makeText(MainActivity.this, "Load Status 8 !!! " + portal.getLoadStatus().name(), Toast.LENGTH_SHORT).show();
pd.dismiss();
break;
portal.loadAsync();
mMapView = (MapView) findViewById(R.id.mapView);
MapViewUtils.setUpBaseMap(mMapView, "https://************/arcgis/rest/services/RehberSB/MapServer", Utils.getUserCredentialsItfaiye());
@Override
protected void onPause() {
super.onPause();
mMapView.pause();
@Override
protected void onResume() {
super.onResume();
mMapView.resume();
}How could I afford to call addDoneListener ?
Thanks for helpings.
