me again
Trying to find the best route for my (about 1000) points.
I am using the network provided with StreetMap Premiun installed on my PC (everything I am using is on my machine)
- I projected my data in the same GCS of ND (just for excluding any complication related to the transformation)
- I set the environment rule for the processing extent as per my data extent (as I am using a huge dataset I thought that using this limitation could have been of help, but I am not sure if NA follows this env. restriction, doesn't it?)
- Geoprocessing Background 64bit is installed (does it help? Do I need to set something in order to have this tool working?)
- Set background processing enabled.
- I use ArcMap 1041
I set the find route.
Impedance minutes (as I am using a visit time I think is the best way)
I use a start time (morning 8:00)
reorder points but preserve the first one.
use hierarchy
ignore invalid
I have tried but using some restrictions and also in "just go" mode (ignoring almost all the limitation).
It takes about 50mins/1 hour and ArcMAp is on (Not Responding)
I also tried to do this: as per my first analysis I have already an order, so I reorderd the OBJID according to this order. If I run the analysis again saying "reorder points" it takes again 1 hour even if the points are already in the right order.
If I run again without reordering it takes 2 minutes.
Now if I want to include some barriers and I want to recalculate the route, same as above if I reorder: 1 hour (of course I need to reorder since I've got a barrier)
If I don't, again a couple of minutes.
What I am asking here, is it acceptable having to wait this huge amount of time for a route?
I also tried with a smaller dataset, and the time decreases as the number of points decreases.
I tried to run the same analysis on PRO and I stopped the process after 1h and 1/2.
With Arcmap the resources' usage doesn't go beyond 40-50%.
Thank you.
